My rca hd tv is an older tv and is rear projection. the volume keeps going down with us doing anything and the menu keeps coming up on the screen while watching tv.
  • 373 Answers
If it is an ITC 222 (seen at the back of the tv) you have the micro switches bad where the on-off /volume and channel up-down are located on the front of the set. They have to be soldered out and new ones put back. Not a costly repair depending on the tech you choose. The front panel has to be removed to get to the switches. All of them need to be changed. A tempoary fix is to use contact cleaner directly onto the switches after taking the panel off, However changing them will fix it for good for a long time
Posted on May 19, 2011
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Have RCA HD50LPW42 Projection TV and the RCA Jacks stopped working both the rear and front mounted. I took it to a TV Repair shop and the guy told me to reset the TV. I looked through the manual when I got...
Go to Menu see if it List Reset Factory settings.
Try with TV off/ Press and Hold ch- and vol- on TV.wait untill TV comes on release buttons and see if Service Menu comes up?
Mar 29, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is wider then the screen on my rear projection tv
Are you using a cable box? Do you have aspect settings on your remote? Comcast cable boxes have a hd zoom button. This will push the sides of the picture out
Apr 22, 2009 | RCA P46921 46" Rear Projection Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca sound and menu problems
Here at my shop we see this problem with these rca sets. The processor is seeing a command from the keyboard or the ir sensor. The most likely cause is a faulty keyboard cuircit board. And replacing is the best coarse of action. To make sure its the problem I remove the keyboard cuicit board and see if the problem goes away. I just use the remote to control the tv, u can also do this until the part arives To get the part you need to know the entire model number. It will be on the sticker in the back in small letters hd52w56yx1 or yx30 or something to that extint. i get most of my rca parts from union electroncs or just let me know and i can look up the part number for you
Nov 12, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Tv problem
if its dlp tv and you still got warrenty trust me take it back and get money while you can ive had two of them dump on me in less than a year and rca cust support dont even want to talk to you
Dec 29, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
