Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
My dishwasher release detergent but I use cascade sachets and I found that after program is done my sachet is out but not disolved and looks like drying cycle just harden block outside of dispenser
2 Suggested Answers
  • 1531 Answers
SOURCE: frigidaire diswasher detergent dispenser
the first thing to make sure is that the incoming water temp is at least 120 degrees.the next thing to do is check your water level and pressure when running if the water pressure is not high enough then you may have to replace the main wash motor.
if you do not think there is enough water in the bottom of the unit after it has stopped fillng add a few more cups to bottom and continue the wash cycle.
if there is no change in the performance replace the main wash motor
Posted on Mar 14, 2010
Wash temp to cold dishes not clean even after #1 wash and detergent does not release either
I suspect the release on the detergent dispenser has failed, I am assuming that the water is heating up in the washing process, you can tell that by feeling the door during the wash cycle.
You have 2 options (if the water is heating)
1 replace the part
2 After it has done the first rinse and filled to do the main wash (or when it has filled to do the main wash without a rinse if you start without a rise) open the door and throw the powder/tablet/sachet into the dishwasher.and it will wash fine The only snag is you have to remember if you are doing a first rinse.If you throw the powder in too early it might drain out
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 02, 2011 | Dishwashers
My Simpson Ezi Sensor is washing clothes leaving grimy tracks and soap powder on the clothes. BeforeI seek any mechanical help, can I put the washing machine through a cleaning cycle of hot water to clean...
Hi from France,
Particularly if the water supply has a lot of calcium in it (hard water), it is necessary to 'clean' it out regularly.
This is done by buying anticalc powder sachets specificaly designed for washing machines (AND often the same stuff for dishwashers!).
If your machine is not new i.e. a few years old and has not hathe benifit of regular cleaning it will be well worthwhile spending some money on these sachets. What I have done with ours is to swith it off, put a couple of sachets into the drum and then pour in (from a kettle or similar) hot water to dissolve the powder. I have then left it overnight so that the heating element is well soaked and hopefully anti-calc'ed. Run a quick wash to flush it out. It will do no harm and hopefully improve its efficiency- IF the problem is due to poor heating and not something else.
I would start there.
Cheers,
John C
Jan 22, 2011 | Washing Machines
Frigidaire diswasher detergent dispenser
Mar 14, 2010 | Frigidaire Dishwashers
Food is staying on the dishes..cheese, bread dough etc.
eggs, cheese, dough are not going to be removed from the dishes by the dishwasher especially if you are using gel type detergents. these need to be removed before they go into the dishwasher. Try a higher end detergent in powder or tablet form. Some of these detergents Cascade Complete have more agressive food disolving agents. They also cost 2 times as much as everything else. Save the money rinse your dishes.
Nov 29, 2009 | KitchenAid Dishwashers
I have suds in my dishwasher. We used cascade and not liquid detergent. I have the Nautilus dishwasher.
sounds like the jet-dri dispencer is leaking and repair is req unless you start to purchase the hanging basket type of jet-dri it will disolve through the normal process don't add anymore liquid jet-dri unit one or the other is done
Aug 23, 2009 | Dishwashers
The soap fails to disolve!
Having the dishwasher powder failing to dissolve is a far more common problem recently with the filing economy.  People are trying to save money by buying generic dishwasher powder rather than brand name products.  The ultra-cheap products fail to dissolve because their ingredients include bulk fillers with minerals, etc.
It is possible that the dispenser is failing to open, but that is a generally rare problem except on very, very old dishwashers. Before deciding the dishwasher has failed, go buy a box of brand name (Electrosol or Cascade) dishwasher detergent powder and only use it.
Please report back your results here, OK?  Good Luck!
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Soap not disolving
is it liquid or powder? we had this problem with cascade powder.... tried liquid cascade and the same thing happened even though i'd been using cascade for YEARS.... manual said could be detergent was "old" and beyond its shelf-life, or that we used too much or too little (go figure that one out LOL).... not trying to promote a brand here, but we switched to palmolive ECO gel and haven't had a problem since -- no goop left in dispenser!.... hope that helps... -cynthia :)
Detergent (gel) always left in dispenser and on bottom of door
Get package of unsweetened limonade drink mix and put in machine and run a cycle, this will clean all parts of hard water deposits. Cascade powder is the manufactors choice, till they get ad space and samle giveaways
Mar 12, 2009 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
97 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
