Question about Acer Gateway NV5614u (LX.WDJ02.001) PC Notebook
Acre Gateway nv51b08u motherboard CMOS location trying to reset password
3 Suggested Answers
  • 42 Answers
SOURCE: reset cmos password for travlmate 630
go to http://tim.id.au/laptops he might have your service manual it,ll show how to remove the bios password
Posted on Feb 24, 2010
matthewt_smi
  • 138 Answers
SOURCE: PC Notebook acre Gateway nv51b08u win 7 64 bit I
your graphics card may not be able to play HD video
Posted on Jun 05, 2011
Bio's Password reset for gateway 98 desktop
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
1. Software removal method - Here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
2. Hardware Removal method :
- First you need to open the case.
- Then find the cmos battery (It will look like a nickel sized silver disk located on the motherboard).
- Remove the cmos battery for 30 seconds and then put it back in. You may have to tweak the bios settings afterward, but the password will be gone.
Good Luck!
Aug 14, 2012 | Gateway Computers & Internet
How to rest bios password on gateway m-7342u
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk. A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
if you need laptop parts ? goto PcPartsLtd.com
May 09, 2012 | Gateway M7342u Laptop Charger...
Need the bios password on my gateway solo 9500
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
Trying to enter BIOS on Gateway 7330GZ and it is requesting a password on a old dos type screen
To reset the bios you must clear the CMOS
There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks.
Let's look at Option #1
By either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
If the "Clear CMOS" jumpers are not present or not available:
Shut down the computer and disconnect the power plug. Locate, if possible, the instruction booklet for your motherboard. Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
for further information read
http://www.dewassoc.com/support/bios/bios_password.htm
May 02, 2011 | Gateway 7330GZ Notebook
Unknow password in bios on gateway solo pro 9300 will not start
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 18, 2010 | Gateway Solo 9300 Notebook
How do i bye pass the bios password in gateway 400VTX laptop
Apr 07, 2010 | Gateway 400VTX-3501335 Notebook
How do I reset hdd password on m285e
Mar 02, 2010 | Gateway M285-E Notebook
Hi, how can i reset BIOS password, notebook Gateway MT6705?
According to Gateway, there is no easy way to change the password. You need to contact Gateway Customer Services and ask for assistance.
Dec 17, 2009 | Gateway MT6705 Notebook
Acer Gateway NV5614u (LX.WDJ02.001) PC Notebook Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
