Question about Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700
Lever is not staying at 9:00 and 3:00 oclock when in lock poiston falls to 6 7 oclock poistion
  • 963 Answers
Here is a link to the trilogy tech library:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
You will find a link to the PDF file for the trilogy 2700 installation instructions on that page, here it is:
http://napcosecurity.com/download/DL2700_WI835_INST.pdf
(Of course you will need Adobe Reader or another PDF file reader installed on your computer to view it). http://get.adobe.com/reader/
When that PDF instruction is opened, you will find exploded-view diagrams of the assembly, allowing you to inspect for any damaged/missing/misinstalled parts.
Hopefully from this you will be able to find your problem.
For further parts or technical assistance, you can click on the "Contact" link found on the tech library link (the first one above), find your state on the map, and navigate your way to the closest Sales Representative, who I'm sure can direct you to further technical assistance and parts that you need.
Posted on May 19, 2011
The hour hand on my grandfather clock is floppy after pushing it back to alter time and just falls to 6 oclock
Push it firmly towards the clock. Usually they are just a friction fit and if you push it, it will jam back onto the shaft.
May 18, 2016 | Watches
Im losing power to system in the start poistion
The key switch may be defective. Ther eis a "starter relay" affialiated with your keyswitch. That can fail. If it has, the starter will not engage. You should hear the starter motor make a failry loud "click" if the keyswitch and starter relay are good.
If the battery terminals are loose or corroded, adequate starting current may not be available to start the motor. Clean/tighten the battery teminals.
If you hear the starte rmaking noises when you try to start the neigne, turn on the headlights and see if they go dark while trying to start the engine. If so, the problem is with the battery or its connections. If the battery is "dead", it may be due to a faulty alternator failing to charge the battery.
Hope these ideas help you.
Feb 11, 2015 | Cars & Trucks
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
Need to know where to set tmming marks
crankshaft mark, 12 oclock, cam shaft mark, 6 oclock.
Apr 09, 2011 | 1985 Chevrolet S-10 Blazer
2001 dodge ram 1500 5.2 v8 van spark plug diagram
firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
The trunk will not open when you pull the lever
this trunk is designed that there a position of the trunk lock that locks that inside handle,some car also use a lever at the latch to disable the inside trunk release,im 1 sure this car uses the trunk lock, take a look and see if you lock out the inside release. if the lock window where you put the key in is pointing at 3 or 9 oclock then its locked the inside release if its at 12 or 6 oclock then the inside release should work and then the cable may be bad, good luck.
Feb 20, 2010 | 2000 Nissan Altima
I have an end of toner life situation on my brother 2040. Can I cheat a few more prints out of it until the new refill arrives?
I dont recomment you use non gen toner, it will cause problems, but cause it is xmas ..... left side of toner cart is reset assy, examine it, there is a lever that falls back once new cart is inserted, this lever need to be placed in 10 oclock position now it at 3 oclock, 3 screws carefull removal and reset into position.
Warning useing a toner longer than it was ever designed for can and probally will damage the drum, powder will run out, developer roller will make direct contact with drum surface and scratch it.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700 Logo
93 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
