Question about Refrigerators
My mother has recently bought a flat and was left the RSB20 Iced Diamond Fridge and she can`t find how to defrost the freezer section. She can`t see a plug or tray to remove. Please can you tell me how to do it. Judy
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
SOURCE: red and green light on
your filter needs to be changed when it is red
Posted on Apr 17, 2008
  • 139 Answers
SOURCE: red light on Hotpoint Iced Diamond freezer
hOPEFULL ONCE YOUR FRIDGE FREEZER GETS TO TEMPERATURE IT WILL GO OFF.. THIS IS THE CASE WITH THIS FRIDGE.
NOTHING TO WORRY ABOUT.
HOWEVER SOMETIMES THIS CAN INDICATE A LACK OF REFRIGERANT IF IT DOES NOT GO DOWN TO TEMPERATURE..
IF YOU NEED ANY FURTHER HELP PLEASE DONT HESITATE TO ASK
CHEERS
WASHDOCTOR
P.S. PLEASE RATE ME AS I HAVE BEEN AWAY LONG TIME AND COULD DO WITH ALL THE HELP I CAN GET LOL
Posted on Aug 27, 2008
SOURCE: Hotpoint iced diamond fridge freezer red light
Buy a new fridge
Posted on Sep 22, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
I have an iced diamond fridge freezer. Turned off unit to defrost freezer. When I turned back on freezer works but fridge never got cold again.
check t ensure that the fan inside the freezer is working properly if the fan is not working inside the freezer then your refridge willnot get cold also if you pull off the back panel inside the freezer you wil see the holes that the air pushes through to go into the fridge section make sure these holes are not blocked if they are your fridge will also not get cold hope this helps if you need a new fan motor for the freezer try marcone appliance uyou can find them online and they directly mail to your door
Jul 13, 2010 | Hotpoint Refrigerators
Fridge section not cooling properly
your evaporator iced up, defrost it, leave it off for 24 hours.Check defrost heater,timer, and the fan motor.
Apr 07, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer works no refrigrator
most common fault to cause this problem is cooling element in freezer section iced up. could also be faulty fridge stat not letting cold air through.first pull drawers out of freezer section, if back cover inside feels frosty or snowy, then likely evap (cooling element) is iced up.if so empty cab, switch off for 24 hours with both doors open, and restart. ice ups can be the result of the freezer door being left ajar, but can also be a problem with auto defrost as well as problem in refrigeration circuit. if problem comes back call a service engineer.
Feb 27, 2010 | Refrigerators
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Feb 02, 2010 | Hotpoint Freezers
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Fridge freezer light on nothing else after transporting.
IS THIS A AUTOMATIC DEFROST UNIT? IF SO THEN THE DEFROST CLOCK PROBABLY IS BAD, LOOK UNDERNEITH BY THE COMPRESSOR AND THERE SHOULD BE A SQUARE ISH BAX THAT HAS 4 WIRES COMING OUT OF IT. TAKE AND TURN THE RED KNOB WITH A SCREW DRIVWER UNTIL THE COMPRESSOR COMES ON. IF THAT WAS NOIT IT TAKE A HAIR DRIER AND HEAT UP THE LIDUID LINE DRIER SOME TO TRY TO CLEAR THE RESTRICTION ON THE DRIER. GOOD LUCK (SORRY ABOUT ALL CAPS BUT GOT TIRED OF CORECTING THE SPELLING) NOT SHOUTING
Jan 11, 2009 | Frigidaire FRT18G4A Top Freezer...
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
