Question about Juki HZL-E80 Computerized Sewing Machine
Can I use a twin needle on my HZL-E80. If so , how?
2 Suggested Answers
  • 3 Answers
SOURCE: double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Posted on Jun 16, 2009
User manual
hi there
i don't know how to upload at fix ya but you can send your email and i will send to you user manual for JUKI HZL-E80 immediately.
thanks and regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 18, 2013 | Juki HZL-E80 Computerized Sewing Machine
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Dirty thread
hi there,can you check please that area around lower needle bar bushing? maybe some oil drop from this area.- check the adjustment screw for lubricate hook from down maybe need to decrease the amount of oil how lubricate the hook by turning to minus direction.best regards
Dec 18, 2011 | Juki HZL-E80 Computerized Sewing Machine
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
Jan 10, 2010 | Juki HZL-E80 Computerized Sewing Machine
I need to know how and where to oil my juki HZL-E80 sewing machine
your machine is not a self oiling machine, you should put the oil on the needle bar, and to the bobbin.
Dec 30, 2009 | Juki HZL-E80 Computerized Sewing Machine
Double needle use on Juki HZL-E80
Jun 16, 2009 | Juki HZL-E80 Computerized Sewing Machine
Thread continues to jam
Hi, my wife and I just bought a Juki HZL-E80... I love the machine. I had a problem like you discribe...This problem can come from two sources...one the bobin has been installed improperly. ...or been wound incorrectly by not haveing adjusted the Bobbin tension ...I did the tension adjustment with the screwdriver supplied with the machine accessories. Also...this is a biggie...the auto matic needle threader works great...but I discovered that when I preformed this function..that I over looked the thread holder that keeps the thread even with the needle....so, the solution is to thread the needle then be sure to check that the thread coming down from the spool is placed behind the little wire holder above the needle...I hope this helps you ...because it is a wonderful machine.....Bill & Donna Bramble...Caldwell Idaho...
May 15, 2009 | Juki HZL-E80 Computerized Sewing Machine
I have a hisico ck563 it's similiar to the juki
check your bobbin, co'z it is not in his right position. and look at your bobbin if there is something who locked it, maybe u break a needle. there is some one left it a litle.
Apr 09, 2009 | Juki HZL-E80 Computerized Sewing Machine
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Juki HZL-E80 Computerized Sewing Machine Logo
41 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
