Question about Tools & Hardware - Others
Hi, I have a Master Fastener 2 1/2 inch (64MM) 15 Gauge nail finish nailer and used very little. When using it the other day it was firing intermittently. Another words, I would press the gun onto my trim board push down and when pulling the trigger you can hear air but it doesn't fire, or at least it did so everyother try and now it doesn't fire at all. There is no jam in the magazine. So not sure if it is just the trigger. Any suggestions?
  • 710 Answers
Hi Alan,
First, be sure you are using the correct nails for the gun. Using the wrong ones will cause it to misfire.
Second, check the nose to see if the pin/piston is bent.
If you have a nail jam this will cause it stop firing. The fact that the gun was misfiring and then stopped completely leads me to think that the pin might have bent and then a nail jammed because of that.
Usually, either the wrong nails or a jammed/bent drive piston is the problem.
Did you oil the drive piston? These guns need friction in the nose piece to operate correctly. Oil will ruin it.
Check the trigger pin to see if it is bent or broken.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 20, 2011
Harbor freight nailguns
Any nail or staple with the same specs can be used. For finish nails it would be the gauge (15, 16, and 18 being the most popular sizes) and angle (if angled and not straight sticks of nails), for staples it would be wire gauge and crown width, for nails it would be the nail diameter (.090, .099, .131 are examples), the nail angle in degrees (NOT counting a roofing nailer, some other coil nailers us slightly angled nails such as 15 degrees) and this is very important with a stick nailer as there are a few different ones out there, and of course max length your tool will shoot of any given fastener. Most boxes of nails/staples will have the specs you need printed on them somewhere and the owners manual will usually contain the same info.
Apr 21, 2012 | Tools & Hardware - Others
Finishing nailer wont fire
Make sure that you do not have a Jambed nail. Open front quick release removed damaged nail and push driver back up with small screwdriver. Make sure to check date on fuel cell befor firing. Good luck
Apr 09, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
Gun fires mor than one nail at a time porter cable model da 250a 15 ga. finish nailer
There are two issues that people have with nailers that sound the same however are totally different. Firing more that one nail at a time can be taken as; two nails being driven with one fire or the nailer vary rapidly firing a second time almost instantly after firing the first nail and each time only drive one nail. Problem of double fire (either type) is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nail head. If you are sure that you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not effect the hardness. You could also check for other brands of 15 g nails with slightly more spacing between the nails. There is a big difference in quality among brands of nails. Good luck with your repair
Jun 01, 2011 | Porter Cable FactoryReconditioned DA250BR...
Skips a nail after each shot
When this has happened to me, I found that the feeder was sticking. This is usually due to a lack of lubrication. Try placing some pneumatic oil onto the feeder area and then trigger the gun a number of times to work it in. (I usually fire the gun without nails for this.) Then load up the nails and try again. Make sure that you add oil to the air stream on a regular basis to keep this from happening again.
Dan
Apr 28, 2010 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Will the nt65ma3 use fn style finish nails
(fn) stands for finish nail,,, and there are different types of those,, this hitachi will use 15 guage, angle finish nails,, do not attempt to put 16 gauage strait or 16 guage angle nails in this gun,
Dec 04, 2009 | Hitachi NT65MA3 2 1/2 Inch 15 Gauge Finish...
Air bypassing when the trigger is pulled, nail gun will not fire
You will need to get a repair kit for that model and brand nailer. It has a leek in the diaphragm or a bad O-ring.
Aug 28, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Aug 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Nailer wont recycle
That would be the cylinder check seal on the outside of the cylinder sleeve. That sits in the groove with little holes in it. When The driver goes down the air goes out the little holes and forms a vacuum above the driver, pulling the driver blade assembly back up. So if the cylinder seal is bad it won`t work.
Thanks,
Yooper Jeff
Mar 23, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
