Question about Pool & Spa
I have a Hayward 1081 pool pump. We have been receiving alot of rain and i went to turn pump on and it keeps tripping the GFI at the breaker panel. Pump was working good until I shut it off prior to rain. any suggestions?
  • 927 Answers
I've had a problem like this. Can you safely power the pump from a non gfi outlet for a while? Once it runs and whatever is causing this condition dries out, you can plug it back into the gfi.
Gary
Posted on May 20, 2011
  • Gary Nigro
    Gary Nigro May 23, 2011
    Thanks for the 4 thumbs up.
    Gary
I have a 220 volt gfi breaker tripping its new install how does the gfi wire up
The bi-metal motor overheat protection switch is internal and it is activating probably with or without the ground fault interrupt they prevent electrocution and other devastation, do not modify anything. Do not hesitate, seek a very experienced pool electrician, NOW.
Jun 01, 2015 | Century B2859 2 HP Centurion 230/115 Volt...
Replaced pool pump motor but breaker keeps tripping
Breakers are mechanical parts and can fail. If none of your components are causing the breaker to trip it's the breaker itself.
Nov 18, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Sep 16, 2011 | Hayward Tristar Pool Pump 1 Hp for In...
My hayward super pump keeps tripping my GFI. The trouble locates to my pump
It could be an overly sensitive GFCI. If you replace it first, because it is cheaper than a motor, then you can determine whether you need a new motor.
I hope this helps.
Sep 11, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
Jandy Stealth 2.0 tripping GFI after heavy rain. Been a week since storm.
Very possibly a bad GFI. GFI's are cheap and worth replacing if in question. also might try hooking up directly to another source and see if it trips a breaker
Sep 13, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Jul 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
929 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
