Question about Xerox Phaser 7700 Laser Printer
Phaser USB Disabled?
I have a used Phaser 7700GX and it prints test pages and info stored inside the printer just fine. However the printer will not print from a computer. I have all the drivers and software so that can't be the problem. When I printed the configuration info it said USB and Ether Talk were disabled. Could that be my problem? How do I enable USB again? Thanks!
  • tvanwey Aug 14, 2008
    USB still disabled according to the printed specs. What about Vram?
    Nevermind I think that was for something completely different
    President:
  • 2,072 Answers
See if you find the settings you need here.
If you do or Do not, let me know and I will send more info.
Phaser 7700 Printer: Enable and disable protocols
  1. With Menus highlighted, press the OK key.
  2. Scroll to the Network Setup menu by pressing the Arrow Down key.
  3. Press the OK key.
  4. Scroll to DHCP/BOOTP, TCP/IP, EtherTalk, NetWare, IPP or CentreWare IS by pressing the Arrow Down key.
  5. Press the OK key. Pressing the OK key will set the protocol to either off or on respectively.
  6. To exit the menu system, scroll to Exit and press the OK key.
Posted on Aug 14, 2008
  • Rick Kasper Aug 14, 2008
    Resetting Network Setup
    Resetting the network setup values will reset the TCP/IP address, TCP/IP address menu settings (gateway, broadcast, etc.), CentreWare IS, EtherTalk, Netware, set IPX frame type, IPP and Ethernet speed to their default values.
    1. With Menus highlighted press OK.
    2. Press the Down Arrow and scroll to Network Setup Menu.
    3. Press OK.
    4. Press the Down Arrow and scroll to Reset Network Setup.
    5. Press OK.
    6. Reset Network Setup NOW is displayed.
    7. Press OK to reset the network setup values.
    Resetting Printer Setup
    Resetting the printer setup values will reset the job defaults, front panel language, intelligent ready, multi-purpose setup, tray 1 - 4 setup, startup page, front panel intensity, front panel contrast, postscript error info and energy star timeout to their default values.
    2. Press the Down Arrow and scroll to Printer Setup Menu.
    3. Press OK.
    4. Press the Down Arrow and scroll to Reset Printer Setup.
    5. Press OK.
    6. Reset Printer Setup NOW is displayed.
    7. Press OK to reset the printer setup values
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
My xerox Phaser 8560 is printing green? It was working fine but now All my pictures have a green hue. Why
I need to know something first. If you print a test page, an internal page, a confirmation page, menu page, etc, does the machine give you a green hue ?
Have you tried to shut the printer down and allow it to reboot? There is tec color correction on your print driver properties. You can try adjustments with that.
But first let me know if the internal prints are ok , then lets go from there.
Jan 18, 2010 | Xerox Phaser 8560DN Laser Printer
Phaser 7760 only prints using black toner (no C, M or Y)
did you try adjusting the settings on the printer driver itself as in go to printers and faxes....right click on the printer and left click properties........under the advanced tab choose printing defaults and change the settings on the printer driver
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
Phaser 7700GX getting yellow bar down the side of page on all prints
Try cleaning the Laser Unit for Yellow. Try replacing the Imaging Unit for Yellow, or simply take it out and move it to another color.... if the problem occurs on the the other color then it is definitely your Imaging Unit. One of those two is probably causing your issue.
Good Luck.
Sep 10, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Duplex printing in xerox 7700gx
Try add a printer and add a generic printer driver ( deskjet 990c), and try the Duplex printing. It should work.
Aug 03, 2009 | Xerox Phaser 7700 Laser Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
