Question about Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire 1 will not boot properly. There ia a small white cursur blinking in the upper left corner. I tried Alt f10 but that did not work:-( Do you have any suggestions?
    Sergeant:
  • 279 Answers
Reboot (by pressing Alt Ctrl Del) press F2 frequently after reboot to go to bios setting. Make sure NO flashdisk/ thumbdrive plugged in to usb port. Choose hardrive as firstboot (in the bios setting under the boot tab) save the changes and exit
good luck
Posted on May 19, 2011
How to factory reset acer aspire 5610 alt + f10 not working
There is no way to reset if you cannot get into the Alt + F10 partition, if you can boot into windows ok then it can be factory defaulted by entering the Acer recovery manager, but if not then you will have to keep trying as it can be difficult to get into, i personally find pressing both keys together once every second does the trick and it has to remain constant, when you see the white line across the bottom of the screen stating "windows is loading files" then simply follow on screen instructions.
Jul 12, 2014 | Acer Aspire Computers & Internet
When i turn on my acer aspire one d255;it only shows - in upper left corner..i can press alt and f10 and go to acers recovery management..but it wont do nothing from there.
Remove the hard drive and reseat it back in place, this is enough in some cases in getting it started, no change! have the hardware tested for possible replacement.
Jul 08, 2012 | Acer Aspire One Netbook 8.9" Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Want to know how to put my computer back to
you need to load the recovery partition.
To do that use a bootable cd like "ultimate boot cd", start "Smart Boot Manager" in boot manager section under "file system tools" and select the recovery partition to boot (it will be a fat32 partition)
Apr 23, 2010 | Acer Computers & Internet
Want to Recovery the complete system on my Acer Aspire 0ne 110. How can i do that?
If you have the original "product recovery" CD-ROMs, re-install Windows from those disks.
Otherwise, is there a "recovery partition" on your computer's hard-drive? If so, then you can reinstall from that partition.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Apr 20, 2010 | Acer Aspire One PC Notebook
Factory reset my laptop
NOTE - you will lose all your data and any installed programs if you do a full factory reset. the process will restore your PC back to how your purchased it
This link will explain how to factory reset the PC using Supplied recovery CDs if you have them http://support.acer.com/acerpanam/desktop/0000/Acer/Veriton5100/Veriton5100faq19.shtml
This link will explain how to factory reset the PC using the ACER eRecovery if installed on your PC
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq67.shtml
If you do have the eRecovery hidden partition installed:- How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Acer Aspire 5315 Notebook
How do i put my laptop aspire 9300 back to factory settings
To Recover your system from within Windows
1. Click on Start, then All Programs, then Acer Empowering Technology.
2. Click on Acer eRecovery Management.
3. If prompted to create a password, create the password and hint
Do not lose this password.
If asked for a password, enter the previously set password.
4. When the Acer eRecovery Management loads click the button labeled Restore.
5. Click on Restore system to factory default.
6. The unit will restart and start the restore.
7. At the eRecovery Management menu it will ask you how to restore.
To recover your system from bootup
Jan 31, 2010 | Acer Aspire 9300-3716 Notebook
My Friend Has a acer laptop He can not get passed
Regards.
Jan 15, 2010 | Acer Aspire 3680 Laptop
Aspire 9500 doesn't start - cursor and drive indicator blinks
Generally the bios setting will be set to check the primary Hard disk for the Operating system and then move to the CD/DVD drive . It looks like your system is not finding the hard disk. Thats why its moving on the CD drive and trying to read it.
Possible issues :
1) Hard Drive crash
Solution : Nothing much. You need to replace the hard drive and reinstall the OS.
2) Hard Drive connection issue.
Solution : Open the chasi and try to figure out if the hard disc is properly connected.
3) Corrupted OS or boot file
Solution : Try to repair the OS use the OS cd and run the repair option.
4) Bios setting to treat CD drive as the primary media.
Solution : Use the F10 option in the Bios to change the primary Media.
Rate the Solution accordingly...
Feb 07, 2009 | Acer Aspire 9500 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
