Question about Garmin Nuvi 760 Car GPS Receiver
My Garnin Nuvi 760 has stopped responding to touch screen. It starts and eventualy opens a map but nothing I touch on the screen will respond.
  • 106 Answers
The problem is probably with touchscreen (a thin film on screen)
You can try order a replacement touchscreen on ebay and replace it yourself
Tip: order a couple of them, they are cheap but extremely fragile
Posted on May 19, 2011
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi will not respond, to touch of screen and screen indicates that map needs to be updated. What do I do to get it to function again
You need to plug in your Nuvi into your computer, once connected go to www.MyGarmin.com
It will then seek your Nuvi model and ask if you like to update maps or update firmware.
I would update firmware first.
Love my Nuvi 760
Oct 19, 2010 | Garmin Nuvi 660 GPS Receiver
Touch screen not working
Your GPS might need a trip back to the factory if the screen has stopped responding to touch. But before doing that, you might want to try the screen calibration routine below:
1) Shut the 760 off.
2) Put your finger anywhere on the screen and hold it there while performing the following steps.
3) Turn the 760 back on with the slider switch and quickly slide it to the lock position.
4) Keep holding that finger on the screen for about 20 seconds or so - then follow the calibration instructions on the screen. You might want to use a stylus or other narrow, blunt object instead of your finger to get pinpoint accuracy.
If this fails to solve the problem, contact Garmin Support directly below:
http://www.garmin.com/garmin/cms/site/us/support/
Please rate this reply if it was helpful - good luck!
Jul 07, 2010 | Garmin Nuvi 760 Car GPS Receiver
Nuvi 760 powers on but the touchscreen will not work
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 25, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Touch screen locked and not responding. Nuvi 660
The touchscreen is intermittent and needs to be replaced. If your unit has a serial # that starts with "12P", "14V" or "143" then you have a style of screen that can fail without physical damage to the screen or glass. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 09, 2010 | Garmin Nuvi 660 GPS Receiver
NUVI 760 2010 MAP UPDATE ERROR CODE 2
The easiest solution is to put an sd card (8gb or less) into the sd slot. Have Garmin Express install to the sd card.
You can also do a hard reset and try to install to the device itself. A hard reset restores the files to factory default, so it may free up enough space.
May 09, 2017 | Garmin Nuvi 760 Car GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 760  Car GPS Receiver Logo
223 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
