Question about Karcher 2500 PSI Pressure Washer
My Karcher 2500 PSI won't give me any pressure when I squeeze the trigger. Do you know what I can do to fix it.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
The list below is from over 40 years of experience.
List of things to do:
1. First off check the screen where the hose connection connects to the unit for debris. Most of time these are plastic screens.
2. Add 2 - 3 ounces of oil into the pump water inlet connection. On upright units it is nearly impossible to do this without a SHORT hose that you can pour oil into that has the male end on it.
Pull the recoil through ignition off or very slow until your sure there is oil exiting the high pressure side of the pump. Leave the Short hose elevated and let it sit over night.
3. Next day first thing pull the recoil through about 3 times slow. Attempt normal use but bleed all the air out of the water supply hose before making the connection to the pump. WATER ON, Squeeze the wand trigger and let all of the air out of the high pressure hose and wand.
4. Start the unit and let it run for about 1 min before squeezing the wand trigger. Squeeze the trigger about every 10 seconds and release. If at this point pressure is starting to increase cycle the wand trigger in half second intervals. (What your doing is attempting to force the bypass un-loader valve to move inside the pump.)
5. If this does not work.... you will have to remove the bypass un-loader valve (Big Knob with locking nut device on the output side of the pump. Carefully remove it so as not to cut the seals. I like to use a couple of drops dish-washing soap for removal. Wipe off / clean the springs and seals. Clean the inside of the pump housing really well. Feel it with your fingers... no rough surfaces in seal area. If you find rough surfaces use at least a 220 grit sand paper by rolling it up and sticking it into the hole for sanding the surfaces. Wipe everything clean. Inspect all seals for tears of cuts (None allowed..replace bad seals) Use WHITE GREASE on the housing seals and springs for assembly. Don't be afraid to use a liberal amount. Assemble and then test following step 3 and 4 above.
This brings about 85 % of them back to life without changing any seals or doing piston work on the pump. The unloader valve sticks most of the time due to either corrosion or debris with the end result of no high pressure. .
Thanks for choosing FixYa,
Kelly
Posted on May 19, 2011
Presure relief value not working when let off trigger on wand
sounds exactly like the problem and the soluition you are looking for.
Mar 12, 2010 | Karcher 2500 PSI Pressure Washer
Power washer loses pressure. Engine runs fine. Taking the nozzel off, squeezing the trigger, and then putting the nozzel back on sometimes remedies the problem. How do I fix it? Thank you.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Sep 29, 2009 | Karcher 2500 PSI Pressure Washer
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Engine cutting out
Check that the fuel is flowing, there should be an fuel filter, check it out.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
87 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
