Question about Toshiba Wireless Mouse PA3205U-1ETC
Wireless mouse pa3706e-1et1 no longer operates my computer even though new battery installed and software re-installed.
  • 2,229 Answers
Aside from the fact that the mouse may have gone bad, have you tried pushing the "connect" button on the bottom of the mouse? Also, is the battery in correctly?
Change the USB port to see if that helps.
Posted on May 19, 2011
Connect my leeds 1690 wireless mouse to my laptop
hi Shon.
Connecting a Mouse with a Wireless Receiver.
Plug in your mouse's receiver. The receiver should fit into one of your computer's USB ports. You can typically find USB ports, which are thin, rectangular slots, on the sides of laptops and on the front of desktops' CPU boxes.
  • Plugging in the receiver before turning on the mouse will allow your computer to install any drivers or software needed to use the mouse.
Make sure that your mouse has batteries. To do so, you'll typically flip the mouse over and remove a tray on the bottom, though some mice instead have their batteries in a compartment in the back of the mouse.
  • If you haven't used the mouse in several months, consider replacing the batteries even if they were new when you inserted them.
  • Some mice, such as the Apple Magic Mouse 2, require charging instead of new batteries.
  • 3
    Turn on your mouse. This typically involves manipulating a button on the bottom of the mouse, though you may need to look for the On/Off switch on the side of the mouse.
    • If you can't find the On/Off button, consult your mouse's manual.
    Press your mouse's "Connect" button. This button's location will vary based on your mouse's developer, but you'll usually be able to find this button either between the two mouse buttons or on the mouse's side.
    • Some mice come listed as "plug and play", meaning that you don't need to manually connect them or download any software.
    5
    Move your mouse around. Once you see the cursor begin to move on-screen, your mouse is connected.
    • If your mouse doesn't start moving, try turning it off and then back on. If applicable, you may also want to change the USB port into which the receiver is plugged.
    this link will help you out some more if you need it.
How to Connect Wireless Mouse
Dec 08, 2017 | Leeds Computers & Internet
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
Hi, I have a Toshiba Wireless Multimedia Keyboard with integrated Touch slider and built in Touchpad/Mouse. Model No PA3705D-1ET1 Wireless RF 2.4GHz but no longer have the USB dongle that came with...
Hi Cliff. I might have a USB dongle for this keyboard if you still need one? See photo attached. As far as I'm aware this still works - our keyboard packed up so we got a new one and just put this in a drawer! Let me know if this is any use to you. Kind regards Tanya
Mar 05, 2018 | Gear Head WIRELESS keyboard/Mouse
My Gateway computer came with a USB connected/wireless keyboard/mouse. I am operating under MS Vista Home Premium. Suddenly the keyboard continues to function; however, the mouse is not working properly....
If its a logitech I would definitely encourage you to go to logitech.com and download the software for your devices. Logitech has excellent mice and with their software installed they run real well.
Apr 07, 2011 | Logitech Computers & Internet
Why will wireless mouse M305 work on my old computer but not on newer computer? The batteries are fine but it won't work even though we tried in several usb locations but still nothing.
Maybe it needs to be installed on your new computer?
Find the installation software, drivers, etc. at this link:
http://www.logitech.com/en-hk/notebook-products/mice/devices/5484
Nov 08, 2010 | Logitech Cordless Mouse
Hi there, I've got a Toshiba mouse, model number
Maybe mouse needs new batteries.
Take that "Small(wireless) part and put try it in another usb port
Aug 25, 2017 | Toshiba C99704 Mouse
Hi there, I've got a Toshiba mouse, model number PA3706-1ET1. It's a wireless mouse and each time when I turn on the computer the mouse stops working. So, after a couple of times removing that small...
first check the batteries inside the mouse they might be low, if that didn't work then try that muse on a different pc to make sure whether it is form the wireless mouse or from your workstation (windows problem or driver corruption).
Apr 18, 2010 | Toshiba C99704 Mouse
Toshiba Wireless Mouse (PA3706E) not working
just install new battery and press the conncet button in mouse .
Dec 18, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
My MX1100 cordless mouse no longer recognized
It sounds like the Drivers for the Mouse aren't be installed. Since it is a wireless mouse and receiver it will need separate drivers to function properly. If it came with a CD I would try re-installing any software that came on the disc. If not (I'm assuming its a Logitech Mouse here) I would visit the Logitech website (www.logitech.com) and see if you can locate Drivers there.
Jul 08, 2009 | Computers & Internet
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Toshiba Wireless Mouse PA3205U-1ETC Logo
328 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
