Question about HP LaserJet P3005 Printer
I have a HP laserjet P3005 printer & when it prints the paper comes out all wrinkled & the toner smears on the right side of the page. This is something new that just started happening, the printer is about 2 yrs old.
  • 30 Answers
The problem is most likely with your fuser which is located in the rear of the printer. You may want to remove the fuser to inspect it for visible damage to determine whether it need to be replaced or not. I have a HP laserjet - broyyce.pngWhile looking at the back of the printer, pull the rear output door open. Push the door down to disengage the rear door stops (1). You will need a phillips head screwdriver to remove the two screws on each side of the rear cover. Lift the bottom of the cover first to disengage the alignment tabs at the top of the back cover, and then lift the cover away from the printer.
Remove the duplexer inlet guide by releasing two tabs (1) on the guide, and then sliding
the guide toward the back of the printer.
Disconnect two cables at the right, inside, of the device (callout 2), and then disconnect the fuser
power cable at the left side of the device (callout 3).
Remove three self-tapping screws (callout 4) and one grounding screw (callout 5).
Tilt the fuser slightly toward the back of the device, and then slide the fuser out of the back of the
device. Look at the two rollers inside the fuser and turn the gear on the side as you look at it. There may be something stuck inside the printer that is causing it to malfunction. If you see and damage on the fuser you can buy a new one from http://www.lbrty.com/
Good luck and I hope this helps!
Posted on May 19, 2011
Paper is wrinkled on one side
Hewlett Packard P3005 Fuser
The HP P3005 fuser is located at the back of the printer.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Jan 16, 2011 | HP LaserJet P3005 Printer
My HP Laserjet P3005 is almost 2 years old and needs a new fuser assembly. Is this normal? How much should this cost? Would I be better off buying a new printer
The fuser is suppose to last up to 200,000 pages, however they rarely get that far.
RM1-3717-020
Dec 07, 2010 | HP LaserJet P3005 Printer
Problem with paper feed - all sheets come out wrinkled with smeared ink print
Sounds like your fuser is bad, ink is not adhering to the paper and building up on a roller that is causing the paper to wrinkle.
Oct 21, 2010 | HP LaserJet P3005n Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet P3005 Printer Logo
470 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
