Question about Ovens
Hi i have a belling oven model number XOU252 and for the past year and half the oven element keeps blowing. It will first start my tripping my mains electric switch which can go on for weeks then the element blows but i am now on the tenth element that has gone into this cooker. There must be something that is causing it to go all of the time. I am now refusing to buy another element until i can find out the cause as its costing me a fortune. Please can you help me.
    Scholar:
  • 52 Answers
ISOLATE THE MAINS BEFORE OPENING ANY PANEL
Remove the rear panel, there is a component with two terminals screwed to the chassis, read whats on it, take a note of the letters and numbers, get a replacement, from a local electrical store, or www.whitegoods.co.uk you will need the model and serial number, this component stops the cooker from over heating, the elements have to be controlled, the second cause is fan running too slow, if the fan does not cause enogh pressure the element will over heat.
Hope this has been helpful
John
Posted on May 20, 2011
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
