Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Handle will not stay up, piece broke off. Model 3750T How can I replace it myself.
    Guru:
  • 1,833 Answers
For any parts of Bissell 3750 Lift Off Bagless Upright Vacuum, please visit this link "http://www.ereplacementparts.com/bissell-3750-liftoff-bagless-upright-vacuum-parts-c-129994_129996_130140.html" - this may help you. you will also find a full diagram here.
Posted on May 19, 2011
How do I replace the handle leaver on my Hoover steamvac F5915 900?
Go to go hoover .com type in your model,ask for blueprint/schematics,look at blueprint ,find your part,cause they will have it, find the part number/price,and they will ship you the part,it's cheaper to fix it yourself, check it out, if I can do it, so can you, if not then pay to have it fixed, I am a cheapo,I fix it myself,also YouTube will show you how to fix it
Jun 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Shark model V1700Z The handle broke off at the
Look it up online. I found a place that charges 7.95 for the part & 6.99 shipping. Get the Model # off the bottom. Mine is V1700Z. And look it up that way on Google or Bing. I think it's listed online as EuroPro.
My servers love this little baby, but they keep breaking that little piece. I understand that the rechargible batteries may wear out in a year, but I have yet to have a handle base last that long.
A Bissel sweeper costs more, clogs faster & does not do as nice of a job. so even if I have to replace it 2x a year, it's not a total, loss
Jul 14, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floppy handle
you have to take the base cover off to find out what broke,there are some screws on the bottom remove those to take the bottom plate off then,then up inside there are more screws to on the top remove the emblem and take that screw out ,that should expose the whole inside of the base.look towards the back where the peddle is and see if there is any pieces laying loose,if there are then you will have to buy the pedal assembl.feel free to call me if you need me to walk you through it.314-628-9153
Sep 30, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Fan and bearing replacement on a Kirby G6
if you run your vac to long after the fan is broke it will cause excessive vibration and the bearings can go out. in almost all cases i replace the fan only. most of the time if you have a bad bearing the vac will make a grinding noise. you can also tell a bad bearing by grabbing the belt pulley on the end of the fan and pull up and down if it moves alot then your bearing is also bad. you can get the bearings separate witout ordering the armature assy. when talking of replacing any of these parts besides the fan i would advise you to take your vac to your local repairman. working on motor parts of a kirby can get pretty involved. to replace the fan first take the housing off where your belt and brushroll are. you should then see 5 screws on the front of your kirby. remove all 5 screws. then remove the handle. at the very bottom of your handle you will see a piece that allows you to move the handle, on the back side of this you need to push in with your thumb and the handle should pull off. then you should see a plastic piece directly below that snaps into the top housing. remove the 2 screws from this. one where the cord boot is and one above your power drive neutral/drive lever. then under this plastic piece is 2 more screws on your top housing. when these are out your housing should pull off. if not then remove the bottom plastic housing of your outer bag. then go back and look at the front again and you will find since removing the top housing you have exposed 2 more screws in the front fan cover housing that also need to come out. after this pry this housing off and you should be looking directly at the fan. grab fan with pliers in one hand and with the other hand apply pliers to the silver belt pulley and turn this piece clockwise. it should unscrew and then you can pull your bad fan off and attach the new one. i hope this helps and remember its not as hard as i probably made it sound. good luck!!!!
Sep 24, 2008 | Kirby G6 Bagged Upright Vacuum
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot find replacement piece for the scrub brushes.
The part number for this brush block is 48437022, most repair shops will have or can get it for you.
Jan 22, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
134 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
