Question about Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Dictaphone 2740 Cannot record. When record botton is depressed machine beeps tape doesn't move and 88.8 flashes on display. Tried to different mics same problem. Has new tape in machine. Thanks Mac
    Problem Solver:
  • 6 Answers
More than likely then the drive belt is broken or the motor is bad.
If you press the reset button the 88.8 flashing should go to 00.0.
If you are sure the tape is good, there is also a switch at the rear of the cassette compartment to detect if the record prevention tab is missing from the cassette itself. If the tab is in the cassette, the switch could be dirty or out of adjustment.
Posted on Oct 30, 2008
SOURCE:
A loud beep on a 2710 dictaphone
There is a couple reasons way your unit can beep.
#1 not tape on the unit
#2 if you trying to record maybe the cassette tab on the cassette is broken to protect a recording
#3 it can be at the end of the tape
#4 try to play and make sure tape moves if tape don't move possible broken belt or bad motor
If none above you can send an email to [email protected] or call (805) 644-9525. Please indicate model and detailed description of problem.
Feb 03, 2014 | Dictaphone Audio Players & Recorders
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Aug 12, 2011 | Dictaphone 2740 Desktop Cassette...
How do i erase a tape on the Dictaphone 2740 transcriber?
Hello Just Press and Hold the erase button located on the bottom rigth then press rewind. All the rewind part will be erase.
Feb 08, 2010 | Dictaphone 2740 Desktop Cassette...
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Dictaphone 2740 desktop.
Try another cassette. There is a tab on each side of the back edge of a tape which when removed will prevent most machines from going into record. If the tab is there (and not bent in), then the switch at the back of the cassette compartment is dirty or out of adjustment. If you can find a manual for the 2740 (try at www.nuance.com, they bought Dictaphone), it will show how to change the Letter display back to a timeline. Good Luck.
Sep 09, 2008 | Dictaphone 2740 Desktop Cassette...
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
124 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
