Question about AEG Santo 3888 KG8 Bottom Freezer Refrigerator
My fridge keeps freezing thing? - AEG Santo 3888 KG8 Bottom Freezer Refrigerator
    Guru:
  • 1,524 Answers
Change the temperature control
Posted on May 19, 2011
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
My fridge keeps freezing things in the fridge
What the most likely thing causing that is that the air damper that opens/closes to let air into the refrig. section is stuck open and too much air is entering into the ref.section allowing things to freeze, that is a fairly common thing with GE refrig's.
To fix that the air damper would need to be replaced..the exact location of it is,upper left corner of the ref. section on the left side wall at the top.
GENE
Sep 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
MY 9 YR OLD FRIDGE IS FREEZING MILK, JUICE AND ALL LIQUIDS IN THE MAIN COMPARTMENT BUT NOT NECESSARILY ON THE DOORS
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
AEG Santo 3888 KG8 Bottom Freezer Refrigerator Logo
252 people viewed this question
Top AEG Refrigerators Experts
ashburton
Ian Jones
David Jewell
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
