Question about Husqvarna Garden
I have a husqvarna chainsaw 41(1994-05) is what the model number is showing the carb has been rebiult new gasgets it has fire but will not run can u help
  • Husqvarna Master
  • 2,239 Answers
The 41 was quite prone to blowing the crank seal on the flywheel side, remove the flywheel and check, at the same time check the flywheel key has not sheared, behind the carb fixing plate is a rubber induction tube, make sure this has not split, als check the impulse seal underneath the induction tube.
Posted on May 19, 2011
What is the carb settings on husqvarna chainsaw
how is the exhaust? if its 2 stroke it needs the exhaust for back pressure. if its 4 stroke, the exhaust isnt as important but it still might be causing issues.
Carb settings vary from carb to carb which is why they are adjustable. Madsen Shop Supply Inc Here is a good tutorial on Husq Carbs.
Aug 15, 2015 | Husqvarna Garden
My Husqvarna model 38096 will not stay running. Cleaned carb, new plug, new gas.
Hi Sonny:
This is the chainsaw section but I think you're playing with a lawnmower, right?
You're saying that it won't stay running. That tells me that it does start, so the spark is OK, and I'd be looking for a fuel delivery problem. Since you cleaned the carb, I'd be looking at a plugged fuel filter or possibly bad fuel.
Jul 09, 2015 | Husqvarna Garden
I have a husqvarna model 359. Starting as per normal with full choke till it fires then half choke to start. Revs up one time then dies and I have to start the process over again. Wont run at all. Any...
Fuel starvation, replace the fuel filter in the tank, check the fuel hose up to the carb, pay special attention to where it leaves the tank as they do perish, failing this then there is dirt in the carb.
May 30, 2011 | Husqvarna Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 137 chain saw - put a new plug in and won't start run if you put a small amount of gas in plugfor just a second or so made sure gas line is not stopped up from tank to carb. less than 2 yrs...
Sounds like the diaphragms in the carburetor have gotten dry and won't flex anymore. Install a new kit in the carb and recalibrate the screws. You should be good to go.
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have husk 359 new plug clean carb fires but will not stay running
This year alone we have replaced 17 carbs,,all warranty,,for this model alone do to the power valve failing.Inside the powervalve{valve jet} there is a very small disc that breaks apart thus not allowing the fuel to flow properly iside the carb.I would contact your local saw dealer and push for a warranty on your carb even if it's still not under warranty because the factory is well aware of this problem.If your carb has # 199 stamped on the side of it push for a replacement.
Feb 20, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
151 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
