Question about Cameras
I have two cameras here that both have problems with the film advance lever, shutter release button and the self-timer. (Phenix DC303N - loose advance lever, and Vivitar V3800N - jammed advance lever) Firstly I would like to know if these problems are linked together!? Secondly would I be able to fix these on my own if you told me how!? Please help! Theyre for a school and i would really like to get these working again :) Hannah Suchy
  • 1,830 Answers
How old are your cameras?
Posted on Jun 26, 2017
SOURCE: Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Posted on Feb 01, 2008
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Posted on Feb 25, 2008
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
voodoomox
  • 1689 Answers
SOURCE: Minolta x370 camera, the shutter
if you are up to repairing the camera yourself, you may want to remove the film first but cutting it from the lock then rewinding it to the tube (make sure you are in a dark room)...
then move to the small article below...
from PointBreak:
The BIG Minolta Shutter Problem Fix Secret EXPOSED!
The Minolta X-Series have been infamous for having their shutters "stuck" and without the film advancing. The LEDS will light up correctly but the film just wouldn't plain advance when you hit the shutter release button. Frustrating to say the least..but alas..alll is not lost. This has been a very common problem and I'll tell you why.
The X-Series, and other possible makers, contains a/an electrolytical capacitor with 1000 hrs of working voltage. When the capacitor reaches its limit it may fail (bulge/corrode). Whether this was an intentional design concept by Minolta is unknown..yeah right! Basically these capacitors hold a small magnetic charge and that when you hit the shutter release it reverses polarity and allows the film to expose, advance, blah, blah, blah..
OK! What I'm going to explain here will save you anywhere from $10 - $200 (meaning you could buy this info. on Ebay or take your X370 to get fixed at a shop). Vendors on Ebay are hocking this info. from $5 and on up..some are actually bidding on this stuff..DON'T DO IT! They will tell you that it's impossible to locate their "product" which consists of new capacitors and the service/repair manual. Well it took some time and research but I have located everything you need so..
Here it is and ENJOY!
1. Download the X370 manuals from http://www.geocities.com/eskoufos/fmm.html. Cost: FREE!
2. Go to http://www.digikey.com/digihome.html. The part number for the capacitor for the Minolta X370 is: P954-ND (Panasonic P/N is ECE-A0GKS221). The actual spec. on the capacitor is: 4v 220uF @ 85 deg. C(entigrade) (6.3X5X2.5 mm).Cost: $7.00 (includes S/H, min. order was 10 pieces @ $2.00 and they charge $5 for S/H)
3. Unscrew the bottom of the camera (4 little screws) and locate the bad capacitor. It's probablu bulging or leaking.
4. If you don't have one, you need a soldering pen and some standard electrical solder. (Go to Radio Shack or any Hardware store)
5. Remove the old capacitor and then solder on a new capacitor. That's it!
if you have other question just lemme know.
Posted on Sep 19, 2008
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Posted on Oct 23, 2008
My Nikon L35 AF's shutter button won't pop back up when I press it down.
Hi Broderick,
You have some (dirt/ dust/ sand) clogged around the clearance between the shutter button and the camera body. If you are a DIY type of person, you can check and clean that dirt, other wise take it to a repair shop for proper cleaning.
Jan 14, 2016 | Nikon Cameras
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
How to put a timer on it for like a self portrait?
After winding the film, press the self-timer lever down all the way. The camera will take the picture about ten seconds after you press the shutter release button.
The self-timer lever is on the front of the camera on the left (looking from the front).
Sep 16, 2010 | Vivitar V3800N Zoom 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Film advance
I removed the advance lever cover as suggested and tightened the screw. This did not solve the issue. However, I then realized the film rewind button on the bottom of the camera was stuck on the "in" position. I could not get it to release which meant I could not advance the film lever to free up the shutter. To solve this issue I removed the bottom cover from the camera (taking out the 3 small screws) and then pulled the advance lever button all the way to the right. This released the button that had been stuck in and allowed me to advance the film lever properly again and take more pictures. Hope this helps!
Jul 14, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
ME dillemma
Also, I just tried the delayed picture-taking lever, ??????? you mean self timer. if you have used self timer then unless the cycle is completed the camera will stuck in the middle, with the mirror locked up. Try releasing the self timer by moving the lever manually. if nothing major defect is theirin the self timer it will release by doing this.
Nov 15, 2006 | Pentax ME Super 35mm SLR Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
