Question about Metrologic Instruments Eclipse MS5145
I need configure the Eclipse MS5145 to Tab..how i make this?
2 Suggested Answers
  • 1833 Answers
SOURCE: I have a problem with
According to your problem, first reinstall the software. You may need firmware update for the scanner. Update he firmware using the software. If it can't solve your problem then reset the scanner. Keep the document in range while scan.
Posted on May 17, 2011
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
My eclipse MS5145 is locked after the first scan , what can i do ?
connect the 2nd end of the scanner cable to a ps2 keyboard and reboot
May 11, 2012 | Metrologic Instruments Eclipse MS 5145...
My mac is not recognizing barcode reader honeywell MS5145
The scanner may need drivers, check for the brand name and go to their website to find the required drivers (if any.) If you already have drivers installed, try other USB ports.
May 04, 2011 | Honeywell MS5145 Eclipse with Codegate...
Trying to restore MS5145 Ecclipse scanner to factory defaults
Hello brett62. I can help you with this. I have the Metrologic Configuration Guide hosted on my website for my clients (www.shiftintoblue.com/resources/metrologic_config.pdf). Go ahead and download that pdf and you'll find the barcodes to recall the unit's defaults. I hope this helps. Good luck!
Jan 07, 2010 | Metrologic Instruments Eclipse MS5145
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Need to ignore + (plus) caracter in barcode
This is done in the software that you are using to decode the scan, call whoever you got it from as there are many packages out there.
Sep 11, 2009 | Metrologic Instruments Eclipse MS5145
I ve lost my scanner drivers. How can i download?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=296
that is the best place to gte the drivers the filkes you need depend on the operating system and the configuration you have for example usb drivers.
Aug 20, 2009 | Metrologic Instruments Eclipse MS5145
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Configuring eclipse 5145
Turning off check digit sending and adding 4 suffixes: 2 cursors left and 2 deletes, solved the problem.
Apr 19, 2008 | Metrologic Instruments MS5145 Handheld
Metrologic Instruments Eclipse MS5145 Logo
261 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
