Question about LG LFD790 System
My LG LFD790 is hooked up to my TV correctly but sudenly will not show up on the screen. The audio is fine you just cant see the picture. I have the TV on and start th LG LFD790 and the blueish LG screen apears for 2 seconds, flickers and then goes blank. The LG LFD790 makes a slight click sound when the screen goes blank. My first thought was a blown fuse but i dont know how to get to the fuses? can you help?
SOURCE: LG LFD790 installed with cable
TV CONTROLLS LFD790
Posted on Jun 18, 2008
Jma11
  • 140 Answers
SOURCE: no sound when using the TV
1- Find the two audio out female RCA jacks on your tv. One is red one is white. Some older tvs may not have any, if so you are out of luck.
2- Purchase a stereo patch cord (male x male RCA) long enough to reach the LG's Subwoofer.
3- Connect the red and white plugs to the tv output and connect the red and white plugs to the "Aux In" female RCA jacks on the subwoofer.
4- Select stereo input for sound on the LG's user interface.
You will be able to upconvert the stereo input to various surrond modes by studying the control manual.
Posted on Nov 30, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
SOURCE: Problems with LG Vu CU920 Cellular Phone mobile TV
the TV icon wont turn off!
Posted on Aug 25, 2009
How do i connect the remote to TV?
This model does not appear to have a connection available to allow TV audio to transmit to the Home Theater System. As such, that which you have experienced will be normal operation.
Check more details at this forum:
Looking for Answers about LG Electronics LFD790
Feb 17, 2015 | LG LFD790 System
Why did my tv picture sudenly darken
The inverter has failed if you still have audio but the screen is black. You can get the inverter from www.tvrepairworld.com
Mar 18, 2013 | LG 42LC2D 42 in. LCD HDTV
Can't get the words for the songs to show on the TV screen
Check whether the output taken from from the Vocopro is from video/audio out. By mistake, if you had connected the RCA cable to the 'input', you won't get any audio or video and also stand a chance to damage both the devices, as video in/out is a very sensitive line.
Aug 05, 2012 | Televison & Video
I would like to incorperate a Blu Ray player into my system. How do I do this? I would also like to run my TV video through the system. The system has been stored and I no longer have the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LFD790-Home-Theater-Systems-manual/id/2771bh539/t/2/
I would recommend any video go directly to the TV, not come FROM it. And the best audio make its FIRST stop at the audio device, not through the TV. Everything you see on a TV these days usually comes from some other electronics, not its own tuner. Fewer interconencts mean fewer problems and less expense from unnecessary cables.
Apr 17, 2011 | LG LFD790 System
LG LFD790: surrond sound only DVD mode?
go to the DVD screen and hit home button, scrool to the "EZ" icon and it will say AUX or OPTICAL. Chose OPTICAL and swich back to cable and you should have sound. This will work, and no the manuel does not tell you this and most techs have no idea. Best luck
Aug 28, 2009 | LG LFD790 System
Hooked to pc....starts up fine at
check your hd settings are correct on your pc.
Apr 28, 2009 | Olevia LT23HVX 23 in. LCD Television
No sound when using the TV
Nov 29, 2008 | LG LFD790 System
Aux
Put the input on the TV to where the LG is selected. This should display the output of the LG system.
On the remote hit HOME, go to Easy Menu and select AUX. Be sure to hook your computer output cables to the AUX sound inputs on the bottom of the subwoofer.
Hope this helps.
Claude in Old St. Lou
Oct 17, 2008 | LG LFD790 System
if there is an input on the back of your cable reciever get a fiber optics cable and put it in to your theater system and into the box then select "ez/optical" and your tv should come through, or you can connect the fiber optics cable on the back of your tv into the system and keep the tv volume off
Dec 25, 2007 | LG LFD790 System
LG LFD790 System Logo
41 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
