Question about Echo Gas Blower 135 MPH390 CFM Blower PB250
Machine runs for short time then stops - Echo Gas Blower 135 MPH390 CFM Blower PB250
  • 85 Answers
May need a carb kit or the fuel lines and fuel filter replaced
Posted on May 21, 2011
The washing machine has just stopped , it's still full of water ?
if its a model with an conventional mechanic/electric program clock you must look if you can hear the program clock is working, and if it is then i think a auto stop in a short worn carbon brush that can be activated to protect the armature for damage of the outcoming spring from behind the brush cannot come between one of the brushholder and commutator. if the programclock is not run then push out the power off and set the clock to pumping draining of the machine thats an other function the function of the pump, if your machineis a budged machine between 4 and 7 years , do not repair but in most cases marketing technical you come from one problem into the next in a short time, replace the machine is the best option.
Mar 24, 2016 | Washing Machines
The foot pedal gets hot after a few minutes
It sounds as though the foot pedal is the problem. Maybe a shorted out wire in the actuator (rheostat). When your foot is off the pedal there should be no power running through it. If it has a short then it "thinks" the pedal is partially depressed to the slow position so runs at that speed. If the pedal can be removed/unplugged from the machine, do this and see if the machine stops running.
Sep 07, 2015 | Sewing Machines
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
.turn mach. on, it starts running and won't stop until you shut it off
sounds like their is a short some where in the machine and it needs
to be checked.
Apr 03, 2013 | Husqvarna Viking 1
Bernina deco 600 keeps running after switching it on
it's possible that something is wrong with the computer
or
there could be a short in the stop button
the machine needs to be serviced
Apr 07, 2012 | Bernina Bernette Deco 600
My machine isnt threading the bobin underneath.
Do you have the right needle in your machine? There are some Sergers that take shorter needles and I have has some customers put those short needles on thier sewing machine. If the needle is too short it cannot pick up the bottom thread.
If that isn't the problem I would also try to rethread the machine and the bobbin. It sounds very simple, but sometimes you can miss a step
If none of the above don't work, you may have a timing issue. Have you run over a pin? or had the needle come down on a presser foot? Sometimes these sudden stops can knock the machine out of time.
Apr 21, 2011 | Brother CS-100-T Computerized Sewing...
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
Water pump turns on and runs for a short time than stops for a short time then starts and then stops. And the machine can not spin because the water is not out enough.
Check the pulley, the belt(s) that turns the pulley and water pump, and check the water pump itself. Also, check for debris in the hose from the tub to the water pump,
Jun 18, 2008 | Hotpoint Washing Machines
Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
97 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
