I need to beable to access Channel 3 on my Emerson TV
  • 5 more comments
  • waltdotbenne May 19, 2011
    The model # is EVC19T5 /// I already called Dish TV and they could not help me with getting it on Channel 3.
    It didn't work
    I don't know anything about a signal hooked to the TV set. I am a female and not trained on any of these things. I need help!!! Does the Model # I sent you give you any helpful info?
    Yes, I have red and yellow jacks, but I don't understand about putting the input on video
    I'm sure my tuner is fine. I just hit a wrong button on my remote. Everything is connected fine. I don't undersstand hooking the the cable to the cable connector. Sorry, this isn't working
    I know where the input button is. I have also gotten the TV to say AUX on the right side at the top.
    I got it on AUX and called Dish and they helped me to get the picture.
  • 373 Answers
If you have your input set to TV from the menu then you can simply type in 03 on your remote. Otherwise you will need to auto program or auto search with a signal hooked to the tv set. It would be helpful to know the model of you set to be sure
Posted on May 19, 2011
  • 8 more comments
  • TV Doctor
    TV Doctor May 19, 2011
    It is possibly you tuner inside the tv. If you have white red and yellow jacks you can bypass the tuner and put the input on video
  • TV Doctor
    You possibly have a bad tuner. You can bypass the tuner using red, white, and yellow RCA cable with color coded input jacks Otherwise you hook the cable to the cable connector and be sure your cables are good
  • TV Doctor
    I could not tell by the model number, However if it is fairly new and an LCD tv or flat screen as many call it you may only need to program the channels
  • TV Doctor
    It is changed from accessing the menu
  • TV Doctor
    The signal is the hookup from the Dish receiver either by cable or RCA cable using red white and yellow. It has to be set up in the menu depending on which one you use either cable or rca cable
  • TV Doctor
    When you use the RCA cable you dont go to channel 3 you go to Video 1 ,2 that is available accessing in the menu
  • TV Doctor
    Look for the input button on the remote
  • TV Doctor
    Make sure you original remote for the TV is working and find the input button on the remote
  • TV Doctor
    Are you sure you Dish system is working?
  • TV Doctor
    Try unplugging you Dish system and plugging back up
How do I change from channel 4 to channel 3 without a remote control?
Why not purchase an inexpensive universal remote and use it to operate your Emerson TV?
Jul 30, 2015 | Emerson Televison & Video
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
Channel setup without remote
Hi I attached product manual link for your Emerson EWC19T4.
I believe that you can find solution.
pdfretriever com
Mar 25, 2014 | Emerson EWC19T4 19 in. TV/VCR/DVD Combo
I need to reconnect the televion and have apparently messed up everying. The televison is just feeding off another television that is connected to satellite. We just had the tv on channel 3 and watched...
If you are trying to watch a diffrent show than from the main tv you will need to get another satellite box. If you do not want to get another box you will only beable to watch what the main tv with the box is watching. To do this just put the tv on chanal 3 and watch wat the main tv is watching.
I have been installing satellite Tv for the last 15 years. If you would like more help please ask. I will try to help you more.
Good Luck
Jan 01, 2011 | JVC AV-27230 27" TV
Can't get channel 3
connect the antenna cable---enter in menu and press autoprogram.
Apr 22, 2010 | Emerson EWF2004 20" TV
What channel to access dvd/hdd recorder? 1 and 2 have no picturel 3 has a picture but no input from dvd/hdd recorder. Thanks, MHF
IN MOST CASES IT IS CHANNEL 3 OR 4. ALSO SOME TV'S HAVE A INPUT/GAME BUTTON THE REMOTE CONTROL WHICH CHANGES THE INPUT TO THE DESIRED LOCATION
Feb 20, 2010 | Emerson EWF2004 20" TV
I cannot get my directv box to work on channel two and three. I can get the game input to work for dvds and games. I also have switched boxes and the they both work, just not on the emerson tv.
It sounds like the tv tuner on the emerson has gone bad if the directv box is not working on channel 3. Try channel 4 on the emerson tv and see if it works. If not you may consider using the game input for directv and disconnecting the dvd player or game console and then reconnecting them only when you use them. You would need to disconnect directv from the game input each time to use the dvd player or game console. Oterwise for simplicity buy another tv. not worth repairing these days
Jun 06, 2009 | Emerson EWF2004 20" TV
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
