AL-1641CS Copier Display alternates between "H" and "4". I have pressed clear button and auto key twice which resulted in a blank screen - where do I go from here?
    President:
  • 2,072 Answers
Once you get the blank screen. Press in the number 14. The tens once and the 4 , 4 times, then press start
Posted on Aug 14, 2008
  • Rick Kasper Aug 14, 2008
    Once the screen goes blank, enter 14 as if you were going ro make 14 copies and then press start. I made that last post clear as mud didnt I ?
I have a Sharp AL-2020 All in One printer. The main power switch works, but the only thing that flashes on the printer screen is "4" and "H" over and over. No matter what buttons I...
To reset the drum light on your Sharp AL2020 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the "auto" key (exposure mode) then the "C" key then the "auto" key again.
So in other words C, Auto, C, Auto
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 20, 2010 | Sharp AL-1530CS All-In-One Laser Printer
I replaced a new drum cartridge for Sharp AL-1631 Copier, but the warning indicator light is still on and the copier is not working.
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Sep 17, 2010 | Sharp AL-1641CS Color Copier
Do you know how to reset the drum counter for Sharp Al-1641
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 30, 2009 | Sharp AL-1641CS Laser Digital Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
We have a Sharp 1641CS copier and the drum light came on a few weeks ago, we replaced it, and the light never turned off, now it blinks, and the will not copy at all? Help!
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then print button
Mar 02, 2009 | Sharp AL-1641CS Copier
FLASHING DISPLAY -
The problem on your machine is on the fusing unit, the temperature in the fusing unit is low to start the machine. To cancel the trouble status follow these steps:
Press CONTINOUSLY the following:
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not do again step 1 until the display turns off.
STEP3.press 14 then press print button
The machine will now cancel the trouble status and ready to used. If not canceled and again H4 exist it means that there is a part inside the fusing unit that is busted like the thermostat. With this you should now contact your authorized serviceman to check your machine .
Feb 27, 2009 | Sharp AL-1641CS Copier
AL-1642CS
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 23, 2008 | Sharp AL-1641CS Laser Digital Copier
Doesnt work
h4 - is a heater lamp error - fuser is not heating up - machine needs the fuser repaired before you can use it, it has probally got a blown heat lamp, could be thermister or thermal fuse but usally on these it isn't. If you a teco happy and 240v comfortable then remove fuser and check lamp and components for open circuit, if you do not know what you are dealing with then dont try.... call a tec, this area runs live 240v
now this is under AL-1641CS but you are saying also  Digi A161
so I'll give you both resets use at own risk do not put in any other number but 14, damage will result, but this code I doubt will help you untill original problem is fixed, oyur machine will reset but error again also.
CLEAR - EXPOSURE SELECT- CLEAR - EXPOSURE SELECT really fast like 2 secs, display should blank then 14 start
or Press: "Clear", "Interupt", "0", "Interupt", "14", "Start Key"
Oct 30, 2007 | Sharp AL-1641CS Laser Digital Copier
Copyer
Sep 04, 2007 | Sharp AL-1641CS Color Copier
