Question about Sony Playstation 3 (PS3) Console
How to get back on the playstation networw - Sony Playstation 3 (PS3) Console
  • 4 Answers
You should be able to connect to the PSN network. But first you must download the new PS3 Software Update 3.61 or something like that. If you try to sign on it well tell you to update. Then once updated you can try to sign on again but you are going to have to reset your password. To do that, it will send you an email to change it. You will have to go to the PSN website to change it, but shouldnt take more than 5 minutes. Once you're done, go ahead and sign on.
Posted on May 20, 2011
I have innstaled the new update and changed my password. but when i try to sign in it says that the connetion to playstation network has expired.. what can i do??
Posted on May 22, 2011
How to on ps2
  • Find a clear space, preferably out of direct sunlight, to set up your PlayStation 2.
  • Plug the AC adapter into the designated area on the back of the PlayStation 2 and then plug it into the wall socket.
  • Plug the RFU adapter or audio/video cords (depending on the model of your television) into the back of your PlayStation 2 and then into your television.
  • Plug your controller into the controller slot adjacent to the disc tray.
  • Plug your memory card into the memory card slot above the controller slot (see "How to Managage a PlayStation 2 Memory Card").
  • Turn your PlayStation 2 on using the on/off switch on the back of the PlayStation 2.
  • Press the eject button to open the disc tray. Insert a game disc and press the eject button again to close the tray and begin play.
  • Turn the PlayStation 2 off when done playing by either flipping the on/off switch or pressing the sleep button.
  • Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
    Tip
    How To Permanently Fix The Red Light Problem On Your PS3 Today!
    The Red Light problem on the PlayStation 3 appears to be a wide spread issue affecting countless PlayStation 3 users. Many users are puzzled as to why this problem struck them; many are dedicated Sony users and didn't believe their PlayStation 3 could be struck down with the PlayStation 3 Red Light problem. It is hard to say what causes the PlayStation 3 Red Light, however we can provide you with some tips that could get rid of the Red Light problem:
    1. Check if there's a loose cable. If not, restart your console.
    2. Unplug all cables except the power cord, and plug them back in.
    3. If that didn't work, then try to take out the hard-drive, and put it back in.
    Learn how to fix your PlayStation 3 today with the PlayStation 3 Repair Program, designed to help PlayStation 3 users effectively banish the PlayStation 3 Red Light problem today!
    Source: Best Yellow Light of Death Fixing Kit
    on Oct 01, 2013 | Sony Playstation 3 (PS3) Console
    Tip
    Playstation 3 no display?
    Have you changed from A/V to HDMI and now cannot get a display?<br /> <br /> Playstation 3 not showing video but playing sounds?<br /> <br /> Follow these very simple steps to bring your Playstation 3 back to life!<br /> <br /> <u>Step 1.</u><br /> <br /> Turn the Playstation 3 off into standby mode (red light on)<br /> <br /> <u>Step 2.</u><br /> <br /> Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep<br /> <br /> <u>Step 3.</u><br /> <br /> Wait for the Playstation 3 display to initialize.<br /> <br /> Your Playstation 3 should now display properly and you can get back to your gaming!<br /> <br /> Hope this tip helps you out.
    on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
    When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
    If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
    1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
    2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
    3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
    4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
    6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
    7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    If that does not resolve your issue, try the other steps here:
    http://us.playstation.com/support/answer/index.htm?a_id=262
    Oct 25, 2010 | Sony Playstation 3 (PS3) Console
    The red light is just blinking and the console is not booting up
    1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
    2) Check if there's any loose cable.
    3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
    If this did not work
    Send your playstation 3 back to Sony
    May 09, 2010 | Sony Playstation 3 (PS3) Console
    My playstation 3 wont come on. The red light keeps blinking. It was working fine the I turned it off for awhile, when I came back it wont come on.
    Playstation light flashing red and playstation not working
    Most of the times, you're going to find that this is due to over heating. If you've been playing for a while, shut down your Playstation, and let it sit for about 1 hour. It's best if the room is cooled off as well.If the room is hot, you may want to put a fan blowing toward it, or turn up your Air Conditioning.Check the back of your unit, and make sure that all of the cables are plugged in. What you're going to want to do is take out each one, and blow the inside of the ports with compressed air.
    To play it safe, take out the Playstation's hard drive, and place it back in.Once the 1 hour is up, and the Playstation hasn't been running, turn it back on, and see if everything is working. If it is, you're good to go! If it isn't, you may want to consult with Sony.
    May 04, 2010 | Sony Playstation 3 (PS3) Console
    While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
    Try resetting the video output. Follow the steps below:
    1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
    2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
    3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
    4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
    5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
    6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
    7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Thank you for using fixya!
    Sep 01, 2009 | Sony Playstation 3 (PS3) Console
    My set of 3 games will not work, disc read error
    I had the same problem with a pinball game I brought. If you have one of the old playstation 2's and these games you have a blue-back on them I noticed after so long they stop playing games with blue-back discs. All other games with out these blue-back discs will play just fine but if you have a new playstation 2 and these games are not playing on there then u need to call playstation and tell them the problem you are having and see what they tell you. Let me know if this helps you Good Luck!
    Dec 02, 2008 | Crave Entertainment Clubworld for...
    Cant send picture messages
    hi sir..    i don't no which model mobile do u have.. i have the solution like this :   go the tools> setting> phone>restore factory setting or reset ... it it will restart the phone.. when i thinking thart it is a correct model .. whether the phone is of gsm or cdma network.. if gsm networw it is a possiblity to work..  thank u sir. rate it..
    Sep 12, 2008 | Cell Phones
    Sony Playstation 3 (PS3) Console Logo
    56 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
