Question about OKI Electric Industry B4600 Laser Printer
I have an Oki B4600. I recently replaced the drum & toner. The print is very light and part of the page is illegible.No error message is displayed. Please advise
  • 30 Answers
The problem is most likely with your fuser and will need to be replaced. Contact Oki tech support and see if your printer is still under warranty, you will need to give them your printer's model number and serial number. Sometimes the cheapest solution is to replace the printer all together.
Posted on May 19, 2011
Err231 then right below there 3E blinking
its a toner tag error make sure you are using correct toner for this type of printer the model #s for colored and blk toner are 43502301(3k) and 43502001 (7K
Feb 02, 2015 | OKI B4600 Printer
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
I just changed the drum and toner yesterday and the print is still really light on the page.... how do I get it to darken up...
use the utility software coming with the printer and execute Maintenance TAB, and proceed according and fix it.
God bless you
Jul 31, 2013 | OKI B4600 Printer
Okidata b4600 printer printing light on some area after replace toner and drum.
Open the top cover and take a damp rag clean LED array (thin black strip attached to cover). Then print a cleaning page.
Mar 19, 2013 | OKI B4600 Laser Printer
We have an Oki B4600 Laser Printer. It is about 6 months old and has started printing vertical white lines through our pages. It originally came with a toner that was half full (I was told) so we quickly...
This is a simple and common problem with many LED print head printers. You just have toner dust on the surface of the print head. Run your finger along the head and all will be well.
Jun 16, 2017 | OKI B4600 Laser Printer
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Aug 07, 2009 | OKI B4600n Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
OKI Electric Industry B4600 Laser Printer Logo
450 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
