Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
I have a white superlock 228 jaguar serger problems with right needle
Hi there, could you tell me why this serger has not had consistent even stitches. Sewing looks fine from top but when you turn it over the looping is very uneven and especially the right needle. The right needle stitch from underneath looks like it's all pulled out. So I disregarded the right stitch needle and use 3 spools of thread for the other left needle and 2 other loopers. I've tried every tension setting and the differential as well. The prescribed setting just didn't work which was 4-2-2-2. I'm just sewing casual cotton wear fabrics. The looping threads would be fine for awhile and then would start to get uneven even when I use only the 3 threads. Thank you.
  • Anonymous May 10, 2009
    I have the same machine with the same problem! I've had it to shop and paid to have it fixed. Lasted a week and same thing, it never stitches evenly.
  • Anonymous Mar 25, 2014
    The top needle thread keeps coming undone when I sew. Need help!
    Problem Solver:
  • 15 Answers
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SOURCE:
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Why do my top thread keep breaking
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? ,,,,,
May 22, 2015 | Sewing Machines
My bobbin isn't working properly it clumps up...
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
Y does my top thread pick up on hook and when it catches bobbin thread it gets tangled up on top of bobbin
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? v
May 21, 2015 | Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Needle not picking up stitches
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
Mylock 634D
The maintenance and repair are recommended every year at a sewing center.
Jan 31, 2009 | Janome MyLock 634D Mechanical Sewing...
Loopy stitches on the back
I have no real solution for your serger, but keep in mind that stitches on the bottom of the work reflect upper thread tension problem, while top stitches are a problem of the bobbin tension( FOR THE MOST PART)
Oct 13, 2008 | Juki MO-644D Mechanical Sewing Machine
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
1,657 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
