Question about Roper REX4634KQ Electric Dryer
I have a Roper Dryer RES7648KQ0, it squeaks really loud while running but the belt seems to be in tact and OK. What would cause this noise? Can I oil or grease an area? Thanks, Jim
  • 5,911 Answers
The noise may be coming from drum support rollers. As the rollers wear with age, they collect dirt, dust and lint and may need to be cleaned and lubricated. If the model number is correct, the rollers can be accessed by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and lift the entire drum with the belt still remove.
The drum support rollers are located along the back wall (bulkhead) of the dryer.
6. Using a screwdriver pry the metal retaining clip off the LEFT roller support bracket. Then, remove the plastic triangular shaped tri-rings off each support shaft.
7. The rollers will slide off the support shaft. Clean any built up lint and debris that may have accumulated around the support shaft. If the rollers are still in good shape, reinstall.
8. Install the plastic tri-rings on both shaft, followed by the support bracket and metal retaining clip on the LEFT roller. Use a small nut driver and place it over the support bracket retaining clip and push on to the shaft to get it to seat properly.
9. Apply a small amount of oil on the each roller at the point where the support shaft inserts through the roller axle. NOTE: Lubricate with a light turbine oil (such as Singer or 3 in 1 brands) at the point where the roller axle meets the shaft. DO NOT get oil on the roller itself or it may cause the drum to slip.
10. Re-install the drum, making sure the rollers are seated properly in the groove around the perimeter in the rear. Make sure the belt is looped around the drum with the groove side facing the drum.
11. Have someone hold the drum in place while you re-install the belt over the tension pulley and motor. If working alone, kneel down so you can see the tensioner and motor and rest the drum front on your shoulder or knee.
With the belt removed, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To re-install the belt the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum.
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.) NOTE: Clean the tensioner pulley wheel (if dirty), prior to reinstalling. Apply a small amount of oil where the pulley wheel meets the axle of the tensior. DO NOT get any oil on the surface area of the pulley wheel as this will also get oil on the drive belt. Oil on the drive belt can cause slippage on the drum.
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Roper is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the rollers require replacement, the part number for a replacement kit is 349241T. The kit includes BOTH rollers, the tri-rings and retaining clip for the support bracket. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 56 and the tensioner is listed as item 53.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number for a replacement is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: A secondary cause of the dryer noise is the rear drum seal becoming worn and requiring replacement. If this is the case, the seal comes as a kit, which includes a special heat resistant cement to glue the new seal in place. You will need to remove the drum and peel the old seal off. Clean the surface area real well. Spread a thin layer of cement on the glue surface of the drum and apply the drum seal. Allow to dry for a few minutes, then repeat, gradually working your way around the perimeter of the drum. DO NOT attempt to apply glue to the entire drum and then try to apply the seal. The glue dries too fast. Work in small sections until the seal is installed all the way around the perimeter. The part number for the replacement rear seal is 279857. DO NOT attempt to oil the drum seal.
Posted on May 19, 2011
Dryer squeaks loudly when running with heat on
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 06, 2010 | Roper REX4634KQ Electric Dryer
Dryer makes loud noise is a ge has thin belt on it. belt is ok seems like the tub doesent turn as fast as it did.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
whn
Mar 09, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Loud squeaking noise
it sounds like your roller bearings are bad you need to get the top open then take the front off loosen the belt take out the tumbler try to squirt oil on the shaft the rollers are on there should be two of them,put it back together and try it,if that doesn't work replace them.
Dec 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Real bad squeaking noise in dryer
Yes check the brake. Just open the back panel and look under the machine. Check the brake latch and make sure that when the unit starts to spin that the brake backs itself off and also make sure that the bad is not worn down. If it is then replace it. A few screws and off it comes. To check the pulley and the belt there is really no wrong way to do it. First look at the belt and make sure that it is not cracked or really smooth. If that checks out ok then make sure that it is attached to the pulley fully and that the pulley is not bent
Feb 13, 2009 | Maytag Performa PAV2200
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
RES7648KQ0
roper dryer model # res7648kq0 will not run. but has power
Jun 14, 2008 | Roper RES7646KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
392 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
