Question about Whirlpool Dishwashers
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the bottom of the dishwasher. We have reset the breaker and checked the plug. Nothing will come on. It's dead.
  • 5,911 Answers
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
Posted on May 19, 2011
  • shoanh May 28, 2013
    i may be having that issue too. Ours stopped in early phase, water is still in bottom. We run it at night, so didn't notice any power outage to it. Other appliances were all normal, but i'd like to troubleshoot it. Can you give me directions? Model GU2300XTVQ3
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
Dishwasher is not turning on...no power
Make sure that the connectors in the power connector box are good. Sometimes they will burn off in the box.The door switches can go bad. the control can go bad. if a whirlpool some Amanas and kitchenaid modekls have a thermal fuse on the electronic board.
Oct 10, 2014 | Dishwashers
Complete power failure mid cycle. No lights or action. Water left in the bottom. please help! whirlpool adp659s many thanks
remove drain hose and see if its blocked at the main drain where it was connected this happened to mine after running CLR thru it
Oct 19, 2013 | Whirlpool Dishwashers
Whirlpool Quiet Partner II dishwasher won't run after power went out. How do I reset it?
I hope it's still in warranty. Usually when power comes back on after a power failure, there is a power surge that takes out electronics.Sad, but true.
Sep 29, 2017 | Dishwashers
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How to clean out pump drain on DU1050XTPQ1
Hello.
(A) Wrench (if necessary) (B) Clean cloth(s)
Thanks.
Nov 05, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
Jul 11, 2009 | Whirlpool 24 in. ADP5962 Free-standing...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
16 year old whirlpool dishwasher model no. DU8950XY-0
Sounds like it is a bad door seal. Recommend replacing the door seal and making sure the door is shutting square and not bent.
Jun 25, 2017 | Whirlpool Dishwashers
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
605 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
