Question about Kitchen Ranges
Broken fence energizer... Parmak mark 7 I am looking for a resource about fixing the circuit board myself do you know of such a place? thanks Maurice robinette
I use to repair all kinds of electronic devises i have a MARK 7 FENCE CHARGER..i believe it had a power surge..after cking it out..my educated guess is the SCR power rect has an open gate ,and need to be replace...as 27ohm 5w resistor smokes..any ideas?
Posted on Jun 04, 2011
I have Parmak S.E.3 fence charger, it's send energy out into wire but not enough to shock cattle, the unit is around a 7 acre field with 2 lines, what could be the problem?
Grounding is very important for an electric fence, especially in dry soil. I normally drive 2 or 3 - 6 foot long ground rods 10 feet apart then join them all together and run that to the charger using double 14 gauge or 12 gauge copper wire. You can get the roda at Tractor Supply.
Aug 19, 2014 | Electrical Supplies
Hi, I have a 25 mile range Parmak solar pak 6 fence charger. When I test the lines it reads .02 and I noticed that the energizer unit itself is energized. I tested the unit and it reads between 3.8 to 4.6....
Any point you measure has to be compared to a reference. This can not be accomplished by just touching one spot....it must be compared to something. Do I make sense the way I explain this?
Hope this helps! Good luck
Dec 30, 2013 | Electrical Supplies
Mark 7 work for awhile and stops
Sounds like the input circut board. they had an issue with a resetable fuse. it will damage the PCB, so it will need the entire board replaced.
Jan 04, 2013 | Parmak Solar Fence Charger
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
12v solar charger is not clicking when turned on.
disconnect the unit from the fence and turn it on. if the fencer work(ticks, meter moves) then it is a fence issue(short, broken wire). if it doesn't then it is an issue with the unit its self and it will probley need a PCB or service.
Oct 22, 2011 | Parmak Solar Fence Charger
We have a Parmak electric fencer, model # s.e.3 and serial # 4401002. It just quit working. When you plug it in it makes this humming sound and then quits. Any ideas?
That sounds like the circuit board has failed in the unit. you can call Parmak and see about either purchasing a replacement circuit board , or getting the unit serviced by them or an authorized service center.
Apr 21, 2011 | Parmak Solar Fence Charger
C lightening hit my mark 7 fence charger is it worth repairing
If lightning hit the unit itself then it more then likely destroyed any electrical components inside the unit. I would say get a new one and dont even bother repairing it.
Apr 16, 2011 | Parmak Solar Fence Charger
When I hook up the ground wire the meter shows not working but when I unhook it, it shows full power.
It sounds like to me that you have something shorting the "shock" output to ground. Check your fence to see if there are any plants, or other objects touching the "Hot" wire to the ground. You could also have a broken or cracked insulator that is causing the short circuit on the output.
joe
Jan 05, 2011 | Parmak Solar Fence Charger
My Parmak solar fence charge does not work. I have new battery. I opened the metal box with all the capacitors and wires and there is a yellow wire that came unsoldered leading from the little electrical...
We have what looks like the same charger. When you open the box right side up, from the front, the yellow wire is soldered to the right side of the circuit board right above the little white box that is marked .47363. It is next to a small round black transister.
Sep 22, 2010 | Parmak Solar Fence Charger
Installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Dec 19, 2009 | Parmak Solar Fence Charger
Kitchen Ranges Logo
228 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
