How do you wire a transfomer and relay together on a central air.(bryant)I took the wires of and now witch wire goes were.I going to change the two.HELP ME
    Novelist:
    Champion:
  • 230 Answers
This may be somewhat difficult depending on the year make and model. I will try to help without this knowledge.
There are 2 sides to the transformer. Read the label to see which is which. One side is labeled 24 volt and the other side is labeled 115 volt.
The 115v side will probably only have 2 wires. A white wire and a black wire. The white one will connect to the common or neutral system. If there is a circuit board it will plug on to the 120v Common terminal (probably marked L2). If the air handler does not have a circuit board, the white wire will connect to the other white common wires by a wire nut.
The Black (hot) 120v wire will connect to the 120v L1 terminal on the circuit board. If there is not a circuit board, read the schematics to find out where to wire nut the black 120v wire to. It will obviously be connected to a 120v incoming hot center after the blower door switch.
The 24volt wires will connect in a similar fashion to the circuit board. T1 will connect to the 24v hot terminal on the board. The T2 will connect to the 24v common terminal. If there is not a circuit board you will need to read the schematics very carefully before proceeding. It may be a good idea to add a 2amp fuseable link on the 24v T1 wire just in the case we are wrong.
The 24v hot wire may be wired in multiple ways without a circuit board. One way is to be wired to the Limit side of the Fan/Limit switch (located on back wall of the burner compartment just above the gas valve. Another way is wired to the gas valve. Please read the schematics located on the blower door. I hope this helps at least a little. Let me know please. Thanks.
Posted on Aug 14, 2008
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
I have a 1985 Honda VT500 Shadow. It bogs down at about 5500 rpm. I changed the 4 spark plugs, checked the air filter, took off the carbs and blew out the bowls, looked clean. Put back together and
there are many air channels in the carbs, witch can be dirty, clean them with very thin wire, and first bled out the gas, check the 2 diaphragms in the carbs
May 20, 2012 | 1985 Honda VT 500 C Shadow
We have a Bryant 556a model, puron Central air saystem. The air handler unit keeps blowing the 5a fuses. I replaced the filter. I cleaned the main contactor at the compressor. It ran for a couple...
The small wires that go from your furnace to the outside unit could be freyed or bare and touching something or maybe even together. Some time dogs will chew these wires outside or under a house if you have a crawl space. You may need to inspect the wires . If looks bad, you can go to a local hardware store and buy new wiring.
I have seen the contactor also blow this fuse. Especially if the contacted are pitted or at time the 24volt coil will be shorted.
These are the two main problems that could be occurring. Good luck. Mark
May 24, 2011 | Bryant Heating & Cooling
How to connect a thermostat to a bryant 80+ furance.
First thing is to turn off the switch on the side of the furnace, next remove the old thermostat and the wires from it. On the new thermostat you should have y, c,w,g,r therminals. The yellow wire goes to the Y terminal, the white wire goes to the W terminal, the red wire goes to the R terminal, the green wire goes to the G terminal and the C is comonly not used.
Jan 01, 2011 | Bryant Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
561CJ060-a bryant air conditioner two control wires disconnected
Sorry if I am answering this 2x. If it is just A/C then the red and white probably go to the coil for the contactor that cuts on the fan and compressor. If it is a heat pump then they probably go to a circuit board. Red to R terminal and White to W1 terminal. Let me know what you find.
May 03, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
5 amp fuse in central Airconditioning unit keeps blowing, I keep replacing, somtime is good for long time and sometime for really less than a day
You have an intermitent short in your low voltage wires. You need to trace the wire all the way to the A/H and then to the condensing unit. I bet you will find a bare spot. Check where the wire goes through the brick to the condensing unit. Ground squirrels are bad about chewing though the insulation. if this is where the short is, replace the wire from the A/H to condensing unit.
Nov 14, 2009 | Bryant 462AJC021BA Air Conditioner
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
