Just replaced the ink cartridge on the printer and get 1/2 inch thick ink lines running the full page of the printouts on the far left side. Even some faint ink lines in the middle of the pages too.
  • 106 Answers
Try to run nozzle check and then print-head cleaning in printer maintenance utility.
Posted on May 19, 2011
When I print a color page, there is a multi colored line about a 1/2 inch thick along the left side of the paper. The print quality is good for everything on the page, just this line of swirled colors. ...
Run the Print Quality test. Sounds like one of the color cartridges is bad.
Also run the Disable Cartridge test. That will let you test each cartridge by itself.
Before you do that, open the front door halfway. Now you can see each of the color drums in each cartridge. One of them may have a 1/2" stripe on the drum on the left side.
Nov 29, 2010 | HP Color LaserJet 3500 Printer
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Color printout has shaded lines; rather than blue background, it prints blue striped background
It sounds like your blue ink may be running out.
If ink is full then try to remove an ink cartridge and putting it back, then run through the steps of printing the test page. It may be just that the pages are printing unaligned.
Aug 05, 2009 | Canon i850 InkJet Photo Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
CHANGING INK CARTRIDGES
For all printers I'm familiar with, it should be on. Some won't even move the carrier (the sliding thing the ink carts go in) over to where you can get to it if you open the cover with the power off. And you'll want to print an alignment page after replacing a cart too or your printout may be blurry (most printers will prompt you to do that after you close the lid).
Aug 05, 2008 | Office Equipment & Supplies
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
It prints ok, but paper is blank (no ink at all)
1. Remove the protective tape from the cartridges:
1. With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
2. Remove the cartridge(s) from the printer.
3. Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
2. Clean the cartridge nozzles:
1. Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
2. Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
3. Clean ("wick") the cartridges:
1. Remove your cartridges following the instructions in your User's Guide.
2. Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
5. Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
6. Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
7. Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
8. Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
9. Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
10. If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
4. Reset the ink levels:
Oct 24, 2007 | Lexmark X83 All-In-One InkJet Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
70 people viewed this question
k24674
jasbo
jasbo
