Question about The Learning Company Zoombinis Logical Journey (480593) for Mac, PC
My son has found the zoombinis game and wanted to install it on his laptop but the laptop is new with windows 7 on and the setup states there is a compatibility issue with windows 64 bit. I wanted to know if there was anytype of software patch out there which would help to run this program?
rocksten
  • 6 Answers
SOURCE: I bought Island Odyssey for my son but after the
I think u should uninstall the game and reinstall using WinRAR.You can download WinRAR from this link http://www.rarlab.com/download.htm
Posted on Jun 04, 2009
SOURCE: i recently upgraded windows vista to windows 7. i
well, i thought that windows 7 would have been developed to be compatible with ALL of the previous systems and programs that they were compatible with. as it is, windows 7 DOES have a way in the control panel that helped me out... there's actually a link in the control panel called "run programs made for previous versions of windows" it took a few tries to get the right setup for the game, but it's pretty self explanatory. sometimes it takes a couple of tries to start it up, but now i CAN play Zoombinis on my windows 7 pc.
Posted on Dec 06, 2009
Testimonial: "i finally figured this out on my own, but thanks for confirmation of this working. :) same for me as far as starting up after a few tries."
  • 154 Answers
SOURCE: I have 8.0 version The learning company learnto
This message is asking you to choose the system type of your computer. If you are not sure what that is you can find that information by:
go to start menu
right click on my computer
select properties
when this window pops up you will see system type under the second section that is classified system.
Posted on Apr 01, 2010
computus
  • 487 Answers
SOURCE: Can some1 please tell me how I install quicktime
Hi, try this link: http://www.oldversion.com/QuickTime.html
Hope this helps
Posted on Jul 24, 2010
SOURCE: Zoombini's Logical Journey won't start up
If the program produces an error right after hitting the Play button, I had success by launching the file Zoombinis Logical Journey.exe in compatability mode using Window 98 / ME and 640 x 480 resolution. The shortcut that is created during install points to TLCRUN.EXE which was what caused my error.
Posted on Sep 25, 2010
How can install zoombinis on window 7
You should navigate to the setup file on the disc, right click, select 'Properties', choose the 'Compatibility' tab, select the 'Run in compatibility mode for:' checkbox, select 'Windows 98/Windows ME'. Then run the setup program.
Alternatively, you could right click on the setup file and choose the 'Troubleshoot Compatibility' option.
The problem here is that you likely have Windows 7 x64 which has little support for 16 bit programs. You may be able to run your program in Windows Virtual PC (XP mode) if you installed it, but the program will likely run rather slowly.
If the solutions I have provided do not work, then I hate to say this, but you are out of luck.
Jul 01, 2012 | The Learning Company Zoombinis Logical...
I put the disc in. click install on the autoplay. and then nothing happens at all!! why won't the setup show up so i can install the game?
Hi anderswang92
It depends on your OS'es version . The fdriver doesn't run anymore under the most recent Mac and Windows versions .
Best regards ,
fanaudi .
Aug 28, 2011 | The Learning Company Zoombinis Logical...
Can't install "message in a
I found a possible solution for this problem with another older Nancy Drew Game; I would try this solution and see if it helps with your problems.
The game is too old to run on Vista (assuming that's what you have) but it's easy to fix.
Just do this:
•First, uninstall the game.
•Next, reinstall the game--but don't do AutoPlay. Instead, go into my computer, right-click on the game's icon, and choose "explore".
•You need to then find the "setup" icon, and choose "properties". There's more than one "setup" icon, but only one that allows you to choose "properties".
•After that, go to the compatibility tab, and check the box that says something like "make compatible for"...choose XP, or ME/2000 if you want to play it safe.
•Exit out of the My Computer screen (though in Vista, it's just called Computer). On the start menu, open up your **Documents** window.
•Create a new folder and name in Message in a Haunted Mansion, or something you will, without a doubt, remember.
•Go back to Computer, double click on "setup" and start installing.
•Install as normal, but when you get to the part where you save the game, it's very important that you save it in the documents folder you created. Otherwise, it won't automatically create a folder for itself, and problems occur.
Here is the link to the solution I found:
http://answers.yahoo.com/question/index;_ylt=AkRXosX54.vFNS0wRZSOqLjty6IX;_ylv=3?qid=20091127101804AAIwP95
Jan 01, 2011 | Her Interactive Nancy Drew: Message in a...
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
I recently upgraded windows vista to windows 7. i did this for the sole purpose of getting my zoombinis logical journey to work and run. it will not start and i need to know if there's anthing i can do to...
Dec 06, 2009 | The Learning Company Zoombinis Logical...
Jun 03, 2009 | The Learning Company Zoombinis Island...
Feb 18, 2009 | The Learning Company Zoombinis Logical...
Illegal Operation
Hi, sounds like you might have a faulty part in the pc, ie memory or hard drive etc. if you have already installed windows from scratch on the pc and your still getting these faults i would say its the memory or hard drive is faulty..
Have a good new year
John
Dec 29, 2007 | Compaq Armada E500 Notebook
Open Questions:
The Learning Company Zoombinis Logical Journey (480593) for Mac, PC Logo
370 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
