Question about Hotpoint HSS25GFP Side by Side Refrigerator
Door trays I took the door trays out to clean them and can not re-install the large ones on the bottom of the door. What am I doing wrong?
  • 639 Answers
Galwegian
i DO NOT UNDERSTAND???
i GAVE YOU WHAT I THOUGHT WERE GOOD INSTRUCTIONS ON HOW I REINSERT THE DOOR BINS WHEN IT'S A NEW AND UNUSUAL MODEL THAT I HAVE NOT SEEN!
IF IT'S GOOD FOR ME TOO!
WHY WOULD YOU GIVE ME AN INAPPROPRIATE RATING HERE AT FIXYA.COM! WE ARE NOT IN THE HOME BUT WORKING BLIND HERE!
THAT HURTS!
BLESS YOU ANYWAY,
NGFAM1
PS, OUR FAMILY HAS BEEN SELLING APPLIANCES FOR 65 YEARS!
Posted on Sep 02, 2008
  • Neil
    Neil Sep 02, 2008
    Friend,
    ngfam1 At your service!
    I came to your service on fixya.com some days ago!
    But, I did not recieve a rating from you yet!
    Can you please give me a rating at our fixya.com site!
    Bless, You ngafm1
    PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
LG French door bottom freezer. The second pull out tray came off track. How do you fix it?
Examine the first pull out tray and install the second one the same way as the first .
Sep 05, 2017 | Refrigerators
HOW DO I REMOVE TRAY2?
Tray 2 should be the one on the bottom and you should be able to put your fingers under the middle section and pull it out.
Jun 23, 2014 | HP LaserJet 2430 Printer
I have a large upright freezer (Frigidaire) model FFU17FC4AW2. It is leaking water out the corners or the front door. It looks and sounds fine. What is wrong with it and can we fix it? If so, what do we...
Blow out the drain at bottom of coils also it might be frozen ice inside the drain.Pour hot water in the drain tray and wait
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
We have a Konica Minolta Bizhub 350 that is reporting a malfunction-error code C-0001. What is the problem?
C-0001 indicates a "LCT Communication Failure" . LCT stands for Large Capacity Tray. Your machine may have a large tray installed on the bottom. If turning off and unplugging your machine does not solve the problem there may be a loose connection between the tray and the machine. You would have to remove the back cover of the LCT to check the connection, If you do this be sure to unplug the machine from the wall.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Maytag Epic Z Front Load Washer: Code "SD" or "5D" appears. Machine lights indicate "clean", clothes soaking wet still and suds on door window.
The error code is not 5 D it is "S" as in Sierra D. The letters stand for Slow Drain.
I had this code and it was fixed in 10 minutes or less.
Simply remove the bottom panel from the front of the washer. You do this by removing the three screws at the very bottom of the front panel. There is a screw on the bottom left, bottom right, and bottom middle.
Once the screws are removed the front panel should drop down slightly, and then you can remove the front panel.
On my peticular model the drain pump had a very large circular tube with what looks like a twist off handle in the middle.
On mine, you rotate the handle counter-clockwise. It's very stiff at first. This is because of the thick rubber seal that you are rotating against.
After about one complete spin it should get very easy to spin and you unscrew it completely off, and pull straight out.
On mine, the back of the tube you pull out contains a tray that hold junk coming out of the wash.
The tray has holes for water to pass through to get to the pump.
When I took mine out, there was one quarter, and one nickel in the tray. That was all it took to clog the dain holes so the drain water moved too slow.
The on-board computer measures the water flow and can tell if it is moving too slow.
Keep in mind, sometimes the money in the tray must have vibrated off to the side just enough that the drain flow was fine.
My error code would be there one day, and not reappear for about two days. Then it would come back every day for about 3 or 4 days in a row.
It was very irratic to pin down when the code would appear, and when the wash would be fine.
I cleaned out the money and some very minor lint and re-assembled.
Nov 19, 2008 | Maytag Washing Machines
Where is tray one?
I reported the same problem and decided to check one last time before I scrapped the printer. I pulled out Tray 1 (the bottom (large capacity tray) to really check closely. I discovered that there seemed to be a space between the end of the paper and the printer tray. I simply squeezed the space closed and NOW IT WORKS! I keep kicking myself for being dumb.
Jul 11, 2008 | Brother HL 1850 Laser Printer
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
