Question about Delta & Single Handle Shower Faucet
The Screw on the Delta Faucet handle just wont come out (1400 Series single handle). What can i do to take this off
    Problem Solver:
  • 16 Answers
HELLO- Screw could very well be stripped,gentley try to pull on the handle as you turn the screw counter clockwise, if you are able to get the screw out and handle will not come off, chances are you will need to get a handle puller Home depot / local plumbing shop or hardware store. goodluck
Posted on May 19, 2011
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
On my delta shower handle 1400 series i know my set screw is stripped and i can not get it off i really jus wanna break it off and buy a whole new one can someone help me out before i go crazy on the...
You can use any high speed drill bit and drill the set screw out, it should be chrome plated brass, so, it will be soft. If you get your sizing right, maybe, just over the size of hex in set screw, you may be able to save the handle and get the rest of the set screw out. You could also try an "easy out" that will fit in the shole you drill to extract the set screw.
Jun 09, 2011 | Delta & Single Handle Shower Faucet
Leaky shower head
If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
Jun 27, 2010 | Delta & Single Handle Shower Faucet
Series 1400 single handle shower can't get handle off
the local hardware store will sell you a handle puller, cheap, maybe $10
Mar 21, 2010 | Delta & Single Handle Shower Faucet
I have Delta Series 1400 Solid Handle and after taking the tension screw out I can't get the handle off. What do I need to do.
There is a set screw under the handle. You will need an allen wrench (hex head) to remove the set screw. Once you remove the set screw, use force to pull the handle away from the shower wall. If it feels stuck use some force alternating between pushing and pulling (rocking motion). I am including a picture in an exploded view so you can see how it assembles and disassembles for your convenience if you need it. Also if you need to replace any parts for the faucet, the part numbers are designated for easy replacement. I hope this helps and good luck!
Feb 20, 2010 | Delta & Single Handle Shower Faucet
How do you remove cartridge from 1400 series delta shower valve
Take off the handle and the cover piece. There is a large nut holding the cartridge in. Be careful taking it off so you do not twist the cartridge socket off the rest of the valve.
Oct 27, 2009 | Delta & Single Handle Shower Faucet
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Delta Series 1400 shower faucet, no or very little water out of the cold side of the faucet. Plenty of hot water. What can I do to fix this?
Remove the handle by opening the little red/blue cap. Use a hex key to remove the handle. Remove the tope ring holding in the cartridge in. Take out the cartridge and you will most likely see particles blocking it. make sure you use a little valve lube or vasline on the seals before you put it back in so you will have smooth operation. If that doesnt cure it just replace the cartridge at lowes or home depot and bring the old one.
Sep 22, 2009 | Delta & Single Handle Shower Faucet
I have a Delta Series 1400 faucet in the tub/shower. The handle turns left and right for Hot & cold, but I do not know how to adjust total volumne. Is the round know supposed to pull out? It does not...
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Delta & Single Handle Shower Faucet  Logo
1,333 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
