Question about Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV
HI ! Like I have already posted before regarding sony KLV-32U300A ,Click twise and doesent turn on i have to unplug for 5 min, it rarely turns on. I have checked voltage in the bulged main rectifier capacitor (330MF/450V) i found 470VDC. is it abnormal voltage to power on the tv.what can be the remedy.PLs help me. thank u
Previous post here regarding this problem do not work. Relay clicking twice when trying to switch on. Yesterday i decided to sort out the problem as i am a TV technician The set was given to me as the client did not accept the Quote for a new board so i decided to trace the fault. I managed to download the diagram. No caps were faulty !!!!! The problem was found to be on the bleeder side of the power supply. The Set is now working 100 % RESOLDER R81,R80,R47,R48 --------R75,R52,R53,R53--------R11,R12,R13.. Hope you all appreciate the info ;-) My Kid is now happy he can play PS3 in HD lol
dale South Africa ------ THIS WILL WORK !!!!! -------
Posted on Feb 06, 2012
  • dale Feb 06, 2012
    R75,R52,R53,R54
  • 760 Answers
Replace the Capacitor that is bulging.
Posted on May 19, 2011
Ido not understand how bt tv actually connects to my tv
Hello Mate
Is your KLV-32U300A have PCMCIA Card so you can connects easily your BT Tv. but if your TV don`t have that slot so sorry dear you have to upgrade your Tv. And I am surpizse that model is almost 4 to 5 years old, And its still works. (Nop its don`t have the PCMCIA CARD SLTS). Share with me you BT TV model or Device #.
Dec 11, 2014 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Buy KLV-32U300A power supply
Hi.
This model was distributed only in few countries. Replacement parts are not available from third party distributors.
Please contact Sony at the number listed on the owners manual or check your local Sony website for the support contact.
Sony Global
Sony eSupport - Electronics
KLV-32U300A - Sony South Africa
Nov 29, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia LCD KLV-32U300A Symptoms: ~ powering up problem, whenever try to turn on click twice and power goes completely off no standby indicator as well. i have to discharge the stored current in the...
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
May 21, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Whenever i plug my sony bravia KLV-32U300A, it click twice and doesn't turn on,power sign goes completely off. I have to unplug from the power source, wait 5 mins and try again, it rarely turns on, but...
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst, times will come that it will not power up at all. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 17, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Klv-32u300a sony geting power on suddenly goving of
SONY-KLV32U300A
NO STEND BY LED NOT LIGHT
4V FROM POWER NOT FOUND
May 01, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
My Sony Bravia KLV-32U300A 32 in. HDTV-Ready LCD TV just lost the picture. Just see different colors. Hears static sound from the back of the unit. This was a progression. Few days ago, clicking sound...
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
Apr 19, 2009 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV Logo
354 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
