Question about Intel 865G Motherboard
No audio, no ethernet - Intel 865G Motherboard
  • MSCarrick May 19, 2011
    Have you been able to access the BIOS? I can't imagine why it would not be enabled "right out of the box" but check all your BIOS settings.
  • Intel Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Posted on May 20, 2011
The audio of my computer is not functioning
Open your device manager, delete the driver for your sound card and reboot. See if that works.
Aug 11, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
No audio and ethernet driver on the motherboard
you can find most driver for most motherboards on the net.....just type in the model number of the board in google and you should be able to fine most of your drivers
Dec 20, 2009 | MSI MS-6580 Motherboard
No Audio Device for my DELL opti GX60. and no multimedia audio controller same as yellow mark ethernet controller.
For that first uninstall driver for ethernet controoler and audio driver from add remove program.
Also uninstall both from device manager.
Right click on my computer then click on property then hardware ->device manager then uninstall both from that list.
Then download driver from below link.
Click here
Click on above link and select yourt operating system and download audio and ethernet driver then install.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Dell Optiplex GX60 Refurbished Intel...
I need driver for dual ethernet and audio
You do not give the manufacturer of the motherboard; go to their website for a download of the needed drivers. You will need to know the board's model number.
Apr 17, 2009 | Computers & Internet
Question Mark in My Device Manager
dear,
pl install 1st chipset dirver from motherboard cd.2nd install vga/video driver,audio driver,ethernet/lan driver.
when require restart pl restart pc.
Feb 28, 2009 | Acer AOpen AW 724 Sound Card
T 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
ASUS CUV4X-C ethernet adapter not found
i have format my computer and now other devices in computer are demanding software namely Audio Device on High Definition Audio Bus,Ethernet controller,SM Bus controller and Video controller(VGAcompatible)
Jul 31, 2008 | Intel Motherboard
DELL Dimension 2350
I wanted to use the advice by Daniel and it did not work for the Ethernet Driver. My dowload which worked, was R64645.exe and is described here
Nov 19, 2007 | Dell Dimension 2350 PC Desktop
Intel 865G Motherboard Logo
367 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
