Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My 4 person eclipse spa drains down to the seat level, at first it was draining very slowly but after waiting a few weeks I tried to fill it back up and it drain within a hour or so all the way back down. Any suggestions? With all the foam underneath there is really no way to check under it for leaks.
    Top Expert:
  • Dream Maker ... Master
  • 4,292 Answers
Leak at bench seats
Posted on Sep 20, 2017
5 Suggested Answers
  • 246 Answers
SOURCE: SN ?Non Functional High Temp Sensor? error message
unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
Posted on Sep 13, 2009
mdhstore
  • 6 Answers
SOURCE: we have a dreammaker spa, how do we drain it? the
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Posted on Nov 01, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a leak in my Dreamaker Eclipse hot tub.
Thats the problem with Dreammaker tubs, access can be a pain and theres no easy way of getting to the pipes.
I would usually gain acces from the underside which ensures that any holes that need to be made to gain access wont be visible in the future.
Good luck locating the leak.
Kind Regards,
Ian.
http://hottub.synthasite.com
Posted on Jun 18, 2010
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
How do i replace the coolant in my 96 dodge caravan after i flush the system
Make sure all the drains are closed, start filling the rad and allow the coolant time to drain down, then fill again. Keep filling the rad unit it no longer drains down, just make sure to stop filling it when the level in the rad is just barely visible when looking down inside it. Now fill the overflow bottle to the lowest level mark. Start the car and turn you heater on to full heat. Let it warm up to proper temp, may/may not need to put more in rad. Keep an eye on the level in the rad it will expand and may overflow, if it looks like it will overflow use yout tester to remove some fluid. Once you see the coolant flowing throug the rad wait a few minutes, then put the rad cap on. Let it run a few more minutes to get the rest of the air out, then drive like normal. Check the fluid level in the overflow bottle (engine cold) over the next few days fill to proper level as needed.
Feb 18, 2015 | Dodge Cars & Trucks
How to do an oil change for saturn coupe
Dear Lourdes ,go to parts store and get oil for car , and filter for car and a filter wrench that fits filter, raise car so you can under it ,remove drain plug from oil pan in to a container that can be used for recycling and let oil drain avg10 min or so replace drain plug and tighten , use filter wrench to remove filter (unscrewing it ,not over tightening) it ,take new filter put alight film of oil on rubber seal of filter ,put it back on motor ,(not over tighten or under tightening ), lower car and fill motor with proper type of oil and fill to proper level using dipstick to check level,. start and run motor for a few min. then shut off and wait a few min . for oil to return back into oil pan and recheck oil level to be sure it is at proper level .
ok have FUN . ps for 21.00 take it to pep boys . Woody
Sep 05, 2014 | 2001 Saturn SL
What causes brown gooey ring around Dream Maker Eclipse spa and how do i prevent it
try non chlorine shock to shock it sounds like you used a chlorine product with it which will cause a gooey mess if it doesnt go away try to drain clean up everything including the filters or by new then try to use bromine that is more stabile in a spa
Aug 29, 2014 | Pool & Spa
My washing machine drains all the water at the end of the wash, but then slowly starts to fill back up. What is causing this to happen?
Hello cowmeag - From what you are describing, there are two possibilities: the valve assembly may not be seating properly or the Main Control board is sending voltage to the valves. If the valves do not seat properly, water will seep paste the valves and gradually fill the unit. I would recommend unplugging the unit. Wait approximately ten minutes and restart unit. If it still slowly fills, more than likely you water valve will need replacing. Otherwise, the dishwasher has a possible Main Control board failure.
Mar 08, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do you change the oil on a 2006 chevy colorado
This is for the 5 cylinder 3.5 liter engine in the Colorado
1. The drain plug is in the middle of the oil pan on the drivers side.
Use a 15 mm socket or box end wrench to remove the plug. Drain
oil.
2. The oil filter is at the bottom front corner of the engine on the passenger side. Remove the filter. Try not to tip the filter when you
remove it so you don't get oil on other parts of the truck.
3. Rub a small of oil on the gasket of the new filter. Spin on the new filter, 3/4 to 1 turn past when the gasket starts to seat. Hand tighten
only.
4. Reinstall the drain plug. DO NOT OVER TIGHTEN OR YOU COULD
STRIP THE THREADS.
5. Add 6 quarts of oil to the oil filler tube located on top of the engine
in the front and middle of the engine compartment. It shows the location
in the owners manual. Install the filler cap.
6. Start the engine and let it run a few minutes to fill the filter with oil.
Turn off the engine and wait a few minutes for the oil to drain down to
the bottom of the engine. Remove the dip stick and check oil level.
Checking oil level is in the owners manual.
Aug 10, 2010 | 2006 Chevrolet Colorado
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
41 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
