Question about Maytag Bravos MTW6600T Top Load Washer
I have a maytag Bravo washing machine (model # MTW6600TQ0) that isn't working. The water will come out but the basket won't turn therefore F 51 flashes on the screen.
  • Maytag Master
  • 8,220 Answers
F-51 RPS senses rotation when basket ought to be stopped.
Posted on May 19, 2011
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware...
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Nov 14, 2017 | Maytag Ensignia MAV2757AWW Top Load Washer
The model of my LG WASHING machine is WP 750((N,R)(P) AND IT IS A TOP LOADER,THE SPIN BASKET WORKS BUT THE WASHER ISNT WORKING.
Sorry but your description of 'isn't working' has very little detail in it so I am trying 'poor water fill' first:-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 14, 2011 | LG WFT1071TP Top Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Maytag washing machine mah5500Bmodel# put on spin cycle drains out water but wont spin basket
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging
Feb 20, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Topload Bravo washer has the smell of bad well water, or stagnant water on occassion. (I have city water, btw.) Also, no matter what detergent I use or what cycle I wash, or what tempurature the...
I can't be sure without looking at the machine but I have had several of these type of machines the get cloths under the agitator "wash plate thing" in the bottom of the basket. This will eventually clog up the pump but stuff that hangs out in there can really get to smelling after a while. Try removing the wash plate and see if you see anything under there. In the future make sure you use a lingerie bag for all small items to prevent them from getting stuck under the wash plate.
Oct 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Sep 01, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
535 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
