Question about Toshiba HDDR320E04XW 320 GB USB Hard Drive
Hii i have toshiba HDDR320e03x 320GB and suddenly new message appears to me and it says NOT RECOGNIZE , i've tried to change cable and nothing helps !! please help me i really the thing that installed on it and very quick ,, thx
    Problem Solver:
  • 10 Answers
Have you tried to uninstall it from your device manager? When you do that, scan for hardware changes, it might pick it up. Also, try moving it to a different usb port after you uninstall from device manager.
Posted on May 19, 2011
  • James Franks May 19, 2011
    There is also software out there that may help with this. Like Paragon Hard Disk Manager. It will alow you to reasign drive letters and partitions. A very usefull tool.
Bios Problem
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 30, 2012 | Toshiba Satellite A660-ST2N02 Laptop...
Won't see hard drive
Try just removing both cables from the back of the hard drive for about 30 seconds then plug them back in.
Check inside your bios for Large Drive Support or AHCI. If you see AHCI try changing it's setting and see if the drive is recognized. I've seen many times where just changing the AHCI makes the drive suddenly appear.
May 22, 2012 | Gateway SX2850-33 (PTGAZ02032) PC Desktop
My HP G62-355DX goes to a white screen randomly and there's nothing I can do to fix it besides turning it off for a while. I've tried unplugging and plugging the video cable back in and I'
TRY HOOKING THE LAPTOP TO AN EXTERNAL MONITOR IF THE MMONITOR IS OK. THEN ITS THE CABLE CONNECTING THE KEYBOARD TO THE SCREEN. HOPE THIS HELPS. THS HAPPENED TO ME GOOD LUCK
Jan 20, 2012 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
Hooked up my toshiba 320gb portable hard drive and the computer doesn't recognize it.
Are u using windows XP?? Then it should recongnize automatically. If not you ve to install the driver .
Mar 01, 2010 | Computers & Internet
Just replaced the HDD in my Toshiba Satellite M55-S329 from a 100GB to a 320GB after the old HDD failed. Now after replacing the HDD, it does recognize the hDD but I get the error message "pxe-e61 media...
You have to change to boot order in the bios settings, it is currently trying to boot from a network drive, it needs to be set to the HDD you just installed.
Jul 27, 2009 | Toshiba Satellite M55-S329 Notebook
Toshiba HDDR320E04XW 320 GB USB Hard Drive Logo
395 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
