Hi, Vulcan " burwood " gas space heater.I have
  • olmate56 May 20, 2011
    Thanks for that information a freind of mine said he thought it might be something like that so i will check it out.The wiring diagram you were after,would it be the one under the electrical cover box,if so i may be able to help you out,let me know and i will send you a copy.Thanks very much for your help
    Genius:
  • 1,015 Answers
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
Posted on May 19, 2011
Testimonial: "Hi frodo,Thanks for the quick response i will try the advice you mentioned. I will let you know if this works.Thanks again. olmate 56"
  • Jack Spooner May 20, 2011
    Yes that would be a big help.Hopefully if I can see the schematic at least I can see what type of limit switch your unit is using and we can get this working for you.Best of luck and thank you.
    OK , i will send a copy to you tomorrow thank you
Need a knob for a Vulcan Burwood gas heater
have you got the model number or a photo of the heater, I may be able to assist
Apr 11, 2013 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
Were to get a set of candles for burwood gas heater
Ithink I still have some saved away, are they the end or center ones, let me know ill then look
Sep 11, 2011 | Vulcan AUW230A Heater
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Fan does not work
http://docs.google.com/viewer?a=v&q=cache:YD3okKRc2I0J:www.americanwaterheater.com/support/manuals/Pol-March2000.pdf+Vulcan+gas+glo+gas+heater+service+manual&hl=en&gl=nz&pid=bl&srcid=ADGEESjhk6UzCP25N_K8wnNncjckZO62rh_N_ax-LUHRffL6o9xuy6FxjRN6PY5jPKX6y2L8XQ_fG4YFdcpCA6Jw59ltNACBymKTTjiY2BaUBKYm8LsGLb5QGAJYJaX2Ld_8ZdTuotnp&sig=AHIEtbQiJznkaXb6qf85geWYr_N5b0uSIw
Above is a service and installation manual, it has all troubleshooting info inside.
Basically, if your fan doesn't go, it can be: A: The Fan, itself, Check. B: The controller for the fan (Thermostat) Check.C: The Power isn't getting to the main boards. Check.
Jun 08, 2010 | Heating & Cooling
Where to get vulcan gas heater spare parts?
Google vulcan gas heater spare needed it will find it for you
Jul 09, 2009 | Vulcan AUW230A Heater
Need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
May 14, 2009 | Heating & Cooling
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
Mar 29, 2009 | Vulcan Heating & Cooling
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Heating & Cooling Logo
534 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
