Question about Lands Phones
I have a lucent phone that I cant find a model # on, black with 2 rows of buttons (flash redial, hold, spkr, mute, blank) and 12 programmable buttons). I need to know how to program the speed dial buttons, help?
  • 3 more comments
  • carla_lammot May 19, 2011
    I just found the model number (under the handset) 8110M
    When I pres the PROGRAM button I hear the tone, but the instant I press a button to program it the tone disappears completely. Even if I continue the process nothing is recorded.
    I have tried several of the buttons and several different orders; I even tried the "To erase a number stored ona programmable dialing button".
    No the phone is over 10 yrs old and given to me for use by an employer; no manual available
  • carla_lammot May 20, 2011
    I guess I should have been clearer; I have been using this phone for 10 years. I have the buttons programmed for commonly used numbers from a previous job; now that I've changed jobs I want to program them with NEW numbers; so yes, the phone works, and all the functions behind it's keys works; When I press PROGRAM I get the solid tone as noted but when I push ANY other button while that solid tone is sounding, it goes dead, no tone, nothing, like you've hung up. If I press any of the currently programmed pre-dial buttons they continue to accurately dial the number I have programmed them to. The error is in the first instruction; pressing PROGRAM causes a solid tone but pressing any button immediately after that causes loss of dial tone and phone goes silent/dead.
    I give up. Regardless of what we do, the instant I press another button AFTER pressing the PROGRAM button (and getting a solid tone), I lose the dial tone and everything stops. So any instructions telling me to "press the PROGRAM button" and then "press......." won't be any good because any button pressed after the program button is causing the phone to go dead. It's not that important, I can just dial the numbers.
    President:
  • 3,278 Answers
Hello.
I realize that there is no model listed, but typically there should be some codes on the side or bottom of the phone. Without the model number, it would be difficult to provide assistance. But, please provide info found in those areas of the phone and we could go forward.
Hope this helps.
Posted on May 19, 2011
  • 7 more comments
  • NinaE May 19, 2011
    Hello, again.
    Here are the instructions (found online):
    Programmable Dialing Buttons (Speed Dialing)
    The 12 programmable dialing buttons are provided for one-touch
    dialing for frequently dialed telephone numbers. You can store
    emergency numbers as well as feature access codes on these buttons.
    Note: You can program up to 20 elements (digits and
    characters, such as Pause or Flash) on a programmable dialing button.
    If the number you want to store is longer than 20 digits and characters,
    you can do one of the following:
    • Store up to 20 elements on one button; store the remainder of
      the elements on a second button. To place a call using these buttons,
      press the first button, wait until all of the elements have been dialed, then press the second button.
    • Store up to 20 elements on one button; dial the remainder of the elements manually.
    To program any of the 12 programmable dialing buttons (while on-hook)
    1. Press the PROGRAM button to enter programming mode
      • You hear a continuous tone while you are in programming mode
    2. Press programmable dialing button on which you want to store the number
      • Tone is briefly interrupted twice
    3. Dial number you want to program on the button, up to 20 elements
      • The tone reminding you that you are in programming mode
        is interrupted each time you press a dial pad key, the PAUSE button, or
        [Flash].
      • You hear a rapid error tone if you try to enter more than 20 elements
      • You can use the PAUSE button to program a .5 second
        pause between a dialing access number (such as 9) and the telephone
        number, and for certain banking and long-distance services.
        Note: Several depressions of the PAUSE button
        will produce a multiple of .5 second pauses. For example, pressing
        PAUSE 3 times produces a combined 1.5 second pause
      • Programmable dialing buttons can also be used to
        program certain system features. See you System Administrator for
        system feature codes.
    4. To program another programmable dialing button, repeat Steps 2 and 3.
    5. Press the PROGRAM button when you are ready to exit programming mode.
    To dial a number with a programmable dialing button
    1. Pick up handset or press [Spkr]
    2. When you hear dial tone, press the appropriate programmable dialing button
      • Number programmed on the button is automatically dialed
    To erase a number stored on a programmable dialing button
    2. Press button to be cleared twice
    3. Press the PROGRAM button or lift the handset
    Try one of the other 11 programmable buttons to see if there is any difference. Was the phone purchased new ?
    So, when you press any one of the 12 buttons, do you get a tone, error or nothing? Since it is a used phone, wondering if the buttons had been programmed.
    Give this a try (the intention is to reset the phone):
    Pick up the handset
    Hang up the handset
    Also, to see if ANY functions work on this phone, try Redial:
    Redial (With Auto-Pause)
    The Redial feature automatically redials the last number you dialed from the keypad, either an extension or an outside number. Use to save time in redialing a busy or unanswered number. The number you redial can be up to 20 digits.
    The Auto-Pause feature can automatically insert pauses after a dial access number (such as 9) in a redialed number. If you usually wait a short period to obtain a second dial tone after dialing an access code, you can set the waiting time using the Redial feature by programming the Auto-Pause feature as described.
    To automatically redial the last number you dialed
    Press [Redial]
    Number is automatically redialed
    Note: You will hear a rapid error tone if the dialed number is longer than 20 elements.
    To program an automatic pause for redialed numbers
    While the telephone is on-hook, press the PROGRAM button
    Press [Redial]
    Press the appropriate access code (such as 9) and number of pauses in order to have a long enough waiting time to obtain a second dial tone.
    For example, if you need 2 pauses inserted between the access code and the remainder of the telephone number you are dialing, press the PAUSE button twice.
    Note: You may store up to 3 different access code/pause combinations. Each code can have up to 3 characters and up to 4 pauses.
    Press the PROGRAM button again
    To erase all stored access codes
    Press [Redial] twice
    Sorry - the procedure displayed as one paragraph. I'll try again:
    Press [Redial]
    Press [Redial]
  • NinaE May 20, 2011
    Thanks for the update. I'll check further for you.
    See if this helps:
    Pick up the handset
    Hang up the handset
    I found something else online:
    To program Personal Speed Dial codes: 1. Lift the handset and dial #00 . 2. Dial # and the 2-digit code (01-24). 3. Dial ? 21 , the dial-out code if any, and the phone number. 4. Repeat Steps 2 and 3 to program additional numbers. 5. Hang up.
    To use a Personal Speed Dial code: Lift the handset and dial # and the code (01-24).
    To erase a Personal Speed Dial code: 1. Lift the handset and dial #00 . 2. Dial # and the 2-digit code (01-24). 3. Dial ? 21 . 4. Hang up
    The question mark translates to an asterisk or star.
    Hello, again.
    I'm finding conflicting info, but wanted to provide all of it to you. Here goes:
    Erasing a Number in Memory
    2. Press programmable button twice
      OR
      Pick up handset
    Storing Numbers in Memory
    1. While the telephone is on-hook, press the PROGRAM button
    3. Dial telephone number
    4. Press the PROGRAM button
How do I set the time on a Panasonic KX-T7667
You should download the manual from here or check the steps below: Panasonic KX T7667 User Manual
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Aug 09, 2012 | Panasonic Lands Phones
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How do I change the time?
You MUST do it at the Main Extension handset - usually 101.
With the handset on the cradle:
Press Program button
Enter *#
Enter the system password - system default is 1234
Enter 000
Press the Auto Dial/Store button
Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Dial/Store button to accept setting
Press Redial button to move to time
Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Ans/Mute to exit Date & Time
Press Program Button to complete
Feb 12, 2011 | Panasonic KX-T7731 Corded Phone
I need to reset our Redial function, it was lost after a power outage.
To program a redial button press feature 00. press the button you want to make a redial button, and enter feature 05. Press feature 00 to exit porgramming.
Apr 22, 2010 | Lucent PARTNER18 Corded Phone
How do you get rid of the beeping noise when you dial on a Toshiba Business Phone - Model #DKT3210-SD?
Dial Pad and Button Beeps
Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs.
1. Press 3+6+9+Hold(simultaneously).
2. Press 0.
3. Press Feature Button 1 (FB1) to toggle On/Off.
FB1, LED On: buttons beep.
FB1, LED Off: buttons do not beep.
4. Press hold to set the option.
5. You must also go off-hook, then on-hook to exit the program mode.
Mar 03, 2010 | Toshiba DKT 3010 Corded Phone
LUCENT CORDED PHONE REDIAL FEATURE STOPPED WORKIG
Press Feature 00
Press button labeled Redial
Press Feature 05
Press Feature 00
Cheers
Jul 09, 2009 | Audiovox Corded Phone
Redial, transfer buttons
Here is a link to program buttons.
If you want to program auto dials to see when people are on the phone, those must be programmed on a lighted button, follow the procedure to program the phone, and use the left intercom button and the 2 digit extension number.
May 28, 2009 | Lucent PARTNER18 Corded Phone
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
Voice Mail
Your phone system time may be off in general. Have you checked that?
You can usually reset the phone time display form the main console
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From Front Desk Phone
1. Push Spkr button
2. Enter #652
3. Enter Correct time in HHMMSS
4. Push Redial button
5. Push Spkr button
Nov 07, 2008 | Toshiba DKT-2020 Corded Phone
How do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 2 enter 000
Oct 08, 2007 | Panasonic KX-T7456 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
