Question about Samsung CLP 300 Laser Printer
Help I can find the rubber band, I can also locate the plastic tabs but I cannot for the live of me remove the rubber band, help, please, Julia
    Problem Solver:
  • 5 Answers
The only way to do this is with 2 small flat bladed screw drivers when u push them at the same time into the edge where the clips are one either side of the roller the whole roller will come off. If you can see opposite the clips there is a sort of hinge section this hinges down and the whole roller and rubber comes free. I just turned the rubber inside out and refitted it no more paper feed errors. It is a little tricky to reach and you definitely need the screw drivers to slip in the edge as pushing on the little lever to release it wont slip it past the notch that holds it in place. Good luck.
Posted on Sep 20, 2008
I love my Cadet toilet. It looks perfect in my bathroom, but the flush isn't as powerful as I thought it would be. Can someone help me?
The flapper is secured with a rubber band. The rubber band must be removed from the flapper for the toilet to function properly. Please check the flush valve prior to installation and if the rubber band is present, simply cut it and remove it.
Jan 27, 2011 | American Standard Cadet 3 Right Height...
I have a today's kids rocking horse with rubber bands. Anyone have the instruction manual that tells you how to change the rubber bands easily??? we're worried we're going to break it to change the...
Okay, we just replaced the bands and this is what we found. Work on them diagonally, i.e. replace right front then left back and so on. To remove the yellow caps you need to move the red plastic stirrup so you can uncover the screw. When you remove the screw it allows the yellow cap to come off. Do the same on the back bands by turning the red piece. Hope this helps. God Bless!
Aug 05, 2010 | Giddy Up Rocking Horse
How do I remove the battery on a 1981 Yamaha xj750?
rubber band is secured to battery box w/hook.release rubber band,remove battery cable connections lift/slide battery out.
Sep 28, 2009 | 1983 Yamaha XJ 650
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
When changing the print cartridge, the rubber band did not break
I do not know what you mean by clear tape or sponge strip but if by ridged you mean what i think then yeah we are pretty much taking about the rubber band that moves the carriage.
So it got off, huh... it normally happens when someone pulls way too hard the cartridges, anyways, if it got loosen from the right side you need to remove all covers and scanning unit.
to do this please remove the screws on the back side and then remove the black front covers, they are set by pressure on (and some plastic nails) so i recommend you to use a flat screw driver and gently pull. look up for little triangular marks or the plastic nails, any good pressure point. once those black covers are removed, unscrew the screws (i dont know if that's the proper expression sorry) you see and proceed to remove the plastic covers, they should come out easily. then you might not need to remove the scanning unit IF you actually can set the band on again. It goes around a little gear you can actually move towards your left to avoid stretching the band more than needed. good luck!!
if you nee dto remove the scnaning unit please unplug everything on the left side before. should be at least two flat cables and a few others.
Jan 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Bmw 316i
hi markjones, the ignition switch can usually be removed without too much disassembly. First you will need to remove a plastic screw in the upper and lower trim covers. Seperate the covers. You should see a black plastic ring around the mechanical switch. gentley remove the ring. Next remove the rubber o-ring/band. With the key in the iginition and turned to almost to position 1, insert a heavy duty paper clip, or bmw special tool (about $30 from the dealer) into the small hole in the switch. There is a cam in the hole that needs to be twisted clockwise so the cylinder can be removed. When installing a new switch make sure to remove the little tab pice of metal that usually breaks off in the housing. Also be sure to make sure and reinstall the rubber ring/band because they are part of the ews system. If you key turns continuously, or is not able to be removed, the ignition housing and cylinder both will need replaced. Replacing the lock housing is about a 2 hour sequence and can be challenging. I would recommend a shop for that kind of repair.
Jan 19, 2009 | 1996 BMW 318
Samsung CLP300 cannot get the rubber pick up roller back in
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Aug 16, 2008 | Samsung CLP 300 Laser Printer
Ok I got the rubber band out
Hi Julia
Not sure where your problem is in the sequence of things. I am in France writing this so not at home to look at my Printer. From memory, once you have removed the wheel with the rubber band (tyre) on, rotate the band so a good part will be pushing on the paper and put the wheel back on the bar in reverseof how you took it off. The tabs on the wheel lock back in place holding the wheel to the bar. It's TIGHT in there though and I seem to remember it took a little bit of persuassion. However, f it seems impossble, then stop. You don't want to break it now you have got this far.
If this doens't help, drop me a line again in a couple of days as I will be back in the UK then and can have a closer look. I will try and post some pics too. Sorry I can't be more helpfull right now.
Regards
Palwing
Aug 14, 2008 | Samsung CLP 300 Laser Printer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Samsung CLP 300 Laser Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
