Question about Dryers
My Frigidaire Crown Series electric dryer (model # FSEB39RGS0) is getting hot on the outside and shutting off mid cycle. After about 30 minutes I can turn it back on and finish drying the load before it shuts off again. I have checked for lint in the exhaust hose and into the dryer opening and it's all clear and air is coming out. There is also a brown burn mark on the back of the dryer in the center, close to the top. How can i fix this?
rickzilla
  • 706 Answers
SOURCE: Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Posted on Dec 04, 2008
cherico108
  • 14 Answers
SOURCE: Frigidaire dryer overheating and shutting off mid cycle
Usually dryers have the exact opposite problem where the heat does not come on. Because most dryers have thermocouples (rated at 150 & 185 degrees) to prevent the dryer from getting too hot. You may have the blower fan come off of the motor. Check and see if you have air moving out of the vent. Also unplug the dryer and take the back off and inspect the area where it is getting hot. It may be some wires touching the case. Sometimes you can see the problem or smell something getting too hot. Either way be carefull. A dryer that overheats is a fire hazard!
Posted on May 18, 2009
Maytag317
  • 1136 Answers
SOURCE: Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Posted on Jun 01, 2009
mgprice
  • 744 Answers
SOURCE: Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Posted on Jun 24, 2009
  • 1757 Answers
SOURCE: Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Posted on Nov 10, 2009
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Why is my dryer shutting off half way through and smell hot
Good Morning Friend,
I understand that your Frigidaire dryer, model# FFSE5115PW, is shutting halfway through the cycle, and smells hot. Please make sure that the lint filter, lint trap, ducting leading outside, and the outside ducting are free of lint. What can happen, is there is not enough air flow if these are clogged with lint, so your dryer will become hot and smell hot. This could possibly cause it to turn off as a safety feature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire White Electric Steam Dryer -...
Why is my frigidaire dryer quitting after running a few minutes. It runs fine on the no heat so the motor is alright.
Not neccessarily the cool cycle uses less power and pressure from the motor, the winedings on motor may be bad or going out? does it shut down after 20-30 minutes of running? u may also want to check ur venting and ur thermostats the cycling and the thermal cut off, if ur having an over heating problem they can and will shut off the cycle as a safety precaution
Jun 22, 2014 | Frigidaire Electric Dryer
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
Vic
Jun 01, 2009 | Dryers
May 18, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
