Question about Gaggia Brera Coffee Maker
Gaggia Brera - The prime indicator light comes on when you turn or or take out of standby mode. This does not clear up when you turn selector knob to the right let water out and then return to up right position. The machine will go through the prep to enter the brew cycle but then indicator lights return to prime
SOURCE: gaggia titanium leaking water underneath
i had this same problem. the solution is simple if you are a little bit handy.
there is a bad valve inside. i called Whole Latte Love where i bought the machine and ordered a Steam Valve complete - Compact Frame
its part number GA-%0345.R and two O-Rings
the valve that comes with the machine is plastic and the new one is a brushed metal casing. my guess it will last for 10 years!
two screws on the back and the machine is open
near the front, by the steam wand, with a hose attached coming from the heater, is the valve, attached to the knob on the side
two more screws and the valve wrapped in a plastic housing comes out.
open the plastic housing, remove the insulated hose to the steam wand and the water/steam plastic hose that comes in. replace the valve, hook up the two hoses, but back in housing and you're done. attach back to knob on the outside, put back together and in 30 minutes, the Titanium is like new. no leaks.
it sounds daunting but is pretty easy and beats sending the machine back for repair. i can't go a morning let alone a month without coffee from my Gaggia. once repaired, the coffee is hotter too.
Posted on Dec 05, 2007
mirran
  • 515 Answers
SOURCE: Gaggia Platinum vision (not in
You have air in the system.
Try to make a cup of water (tea).
Posted on Aug 16, 2008
  • 1089 Answers
SOURCE: gaggia syncrony compact is leaking. Removed top
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Posted on Jun 14, 2009
McLindy
  • 32 Answers
SOURCE: no water coming through the head after prime etc
I have the same problem. I disassembled the unit body from the boiler. There was some scale, which I cleaned out. However, everything was flowing through the orifices with gravity -- no need to use a pipe cleaner because nothing is clogged.
So then I started tracing the flow of water. There is only one thing between the boiler and the shower head: the solenoid valve (in diagram ER0182 part # 27).
Sure enough, the solenoid valve will not accept water through the orifice that would route it to the shower head. Of course, this is with the solenoid unplugged and removed from the system. I soaked the orifice end of the solenoid valve in some decalcifiying solution in the hope that the solenoid piston may be jammed with a bit of scale.
Now I'm going to reassemble and hope for the best. However, my guess is that my solenoid valve needs to be replaced. Everything else is working (pump, valves, tubes, etc.).
I will report back.
Posted on Aug 07, 2009
  • 80 Answers
SOURCE: Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Posted on Aug 22, 2009
F code on a cabrio wtw6400sw3 sounds like a bearing is going out
its not an f code its an f code then u have to add the applICABLE NUMBER THAT APPLIES.
SEE THE LINK Whirlpool Cabrio Automatic Diagnostic Mode
Here are instructions for entering the technical diagnostic mode. This mode is designed for service technicians familiar with the product testing operation, if you need more instructions, you can find information on the tech sheet located inside the console of the washer as the entire diagnostic process cannot be published on this site. Always disconnect power supply before entering any closed section of the appliance and wear safety glasses and gloves.
1.Be sure the washer is in standby mode (plugged in with all indicators off)
2.Perform the following sequence of movement using the cycle selector knob.
3.NOTE: AFTER RESET, sequence must be completed within 6 seconds.
4.RESET - Rotate cycle selector knob counterclockwise one or more clicks to clear sequence.
5.a. Rotate cycle selector knob clockwise one click and wait ½ second.
6.b. Rotate cycle selector knob clockwise one click.
7.? Successful activation of Diagnostic test modes will be indicated by all status LEDs (except for Lid Locked) flashing ON and OFF in half-second intervals.
8.NOTE: LED names may vary between makes and models.
9.If the status LEDs do not display as described above, the sequence may not have been completed within 6 seconds. Repeat step 2 to ensure this was not the cause Whirlpool Diagnostic Mode
Dec 31, 2016 | Washing Machines
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
to clear sequence.
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
?Successful activation of Diagnostic Test
Modes will be indicated by all status
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Descale alarm wo'nt turn off after a full descale.
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
Nov 10, 2013 | Gaggia Brera Coffee Maker
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Post the results back to me.
Nov 30, 2012 | Washing Machines
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
Does anybody know how to get rid of flashing red exclamation light on my gaggia platinum vogue?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
Oct 07, 2011 | Gaggia Platinum Vogue 90800 Espresso...
Whirlpool Dryer works on 1 cycle
Activate the diagnostic test mode to determine the functionality of the console buttons and the console electronics as a whole.
Diagnostic Mode Activation Procedure
  1. Make sure the machine is plugged and in standby mode. That is, no indicator light is on.
  2. Press the following keypad sequence within five seconds: More Time>Less Time>More Time>Less Time. All of the indicator lights should light up and "88" is displayed.
  3. Turn the cycle selector knob one complete rotation. When the knob points to a cycle, the corresponding indicator light should turn off and the machine should beep. Only a beep is heard when the knob points at the large spaces between the Automatic and Manual cycle groups.
  4. A beep should be heard when a button is pressed and the indicator light corresponding to it should turn off.
Any failure on the above tests indicates a faulty console board. Please let me know the result of the test for further troubleshooting and repair guide.
Jan 22, 2010 | Dryers
Gaggia Brera Coffee Maker Logo
1,721 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
