Question about American Standard "Trevi" Deluxe Showerhead AME-1660.115
Unit leaking badly. I need guidance regarding how to disassemble and where to get new "O" rings. Danchuk@att.net
  • 6,993 Answers
follow the instructions below to successfully disassemble your Deluxe Shower head in order to solve this problem:
Unscrew the showerhead from the pipe coming out of the wall. This can be done by hand but sometimes requires a crescent wrench or large pliers. The head may be held on with a screw, which you'll have to remove.
Look at the threads inside the showerhead where it screws into the pipe. There should be a small washer made of plastic or a rubber O-ring. Replace it if it looks even a little damaged or brittle.
Wrap the showerhead stem with Teflon tape or pipe sealer (pipe dope) to seal the connection.
Remount the showerhead on the stem. Don't overtighten. Hand-tightening should suffice.
Turn the water on and off. Wait several minutes and check for drips or leaks. If the showerhead is still leaking, you may have problems with the shower's water-control valve and need to replace the whole shower head.
Keep me posted....
Regards.
Posted on May 19, 2011
Ruud p40-7 water heater
You can get a sudsy water solution and brush it on all over the place especially around joints and look for a leak via tell tale bubbles. If it is the water heater that has the leak there aren't too many places where you can have the leak and it should not be all that hard to check out.
Mar 24, 2017 | Water Heaters
Garbage Disposal Leaks from the bottom.
Hi GF,
Unless there is a leak at the sink gasket that makes it appear that the unit is leaking from the bottom, it's probably the main seal in the unit. It's generally not worth it to attempt disassembly and repair, especially if the unit is 10 years old or older.
Just remember to make sure the power is off before you attempt any
troubleshooting or replacement.
Be safe...
Aug 18, 2012 | GE Continuous Feed Garbage Disposal...
What causes excessive oil usage in B&S engine?
The piston rings are going bad, or you have a leak some where.
Look for leaks by washing down the unit so you can see where the oil is coming from.
It may only leak when running, so you may have to run it until it warms up and then look for the leak. Most of the time i notice the dipstick tube o-ring is bad at the bottom of the tube. Replace the o-ring to stop that leak.
If its the piston rings, then your motor probably smokes while its running or when you really work the motor such as mowing thick high grass.
You spark plug will be oily and indicate to you that the rings are allowing oil to pass by.
To fix that, you have to freshen up the top end of the motor, with new rings and possibly new piston if the cylinder needs bored.
Check for leaks first, then pull the spark plug and see if its oily.
Dec 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Just received new Att email account with U-verse signup. Trying to set up email thru Outlook 2000. Need to know the ''Incoming mai (POP3)'' name and ''Outgoing mail (SMTP)'' name. Please assist. Email...
If you looking for POP3 SMTP Mail Servers then it would be
AT&T WorldNet incoming mail server: postoffice.worldnet.att.net
AT&T WorldNet outgoing mail server: mailhost.worldnet.att.net
or
incoming mail (POP3) -> ipostoffice.worldnet.att.net
Just for POP, I think should be somethinnd like
MemberID@att.net
or
pop.att.yahoo.com
Incoming Mail Server (POP3):
Host Name: ipostoffice.worldnet.att.net:995
User Name: your_username@worldnet.att.net
Good luck
Nov 24, 2009 | Microsoft Outlook 2003 for PC
Oil in with spark plugs
Your piston rings are bad.
Jun 25, 2009 | 1995 Chrysler Cirrus
Rifle sitting a long time but brand new won'thold air pressure
hi
contact Mac1 out of the US at mac1airgun@att.net.
He would be of help as he modifies these things and has full parts kits available.
or chek this link
www.mac1airgun.com
they sell you the o-rings or customize your gun to another level .
or chek some useful sites
http://www.crosman.com/airguns/service/manuals/crosman-rifles
http://www.fotolode.com/images/Rapidfirex/crosmanpumpmaster760assembly.jpg
hope u will b helpfull
regards
Jun 12, 2009 | Crosman (4032)
2003 Nissan Pathfinder
Oil cooler o-ring.
http://www.nissanpathfinders.net/forum/topic/25463-engine-oil-cooler-leaking-oil/
Not all coolers look like radiators. I wouldn't think it should cost that much. Try somewhere else.
May 01, 2017 | 2003 Nissan Pathfinder
Crossman Mark 1 CO2 Pellet Gun
Check out www.mac1.com. Tim can sell you the o-rings or customize your gun to another level (see the LD pistol).
Steve
Jul 22, 2008 | Optics
American Standard "Trevi" Deluxe Showerhead AME-1660.115 Logo
142 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
