Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultimasimply flashes H20.
Hello, i came in to find it simply flashing H20.. i checked all the pipes and nothing seems to be out of order..i've switched it off and on and managed to get it back to the template selection. I then chose the standard wash but the machine does nothing but count down!
Any advice! before i attack it with a screwdriver and hammer!!!
Eddie
  • 594 Answers
Witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Posted on Aug 17, 2008
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
H20 flashing on the front
This means the water is not on check the pipe and make sure the tap is fully on and try the machine again. if u checked this then check the filter to do this take off the pipe at the machine and there is a filter if it is clear then you can put the pipe back on and try again. Hope this helps.
Feb 21, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My machine is flashing h20
H20 indicates a water supply problem.
Could be frozen pipe, check the hose/s for kinks or restriction, and that you are getting water at the inlet valve/s, and that the water pressure is o/k
Dec 18, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
H20 flashing in digital display
H20 means a problem with the water inlet to the washer.
Check the inlet hose/s are not kinked or restricted in any way. Check the tap/s are fully turned on.
Check that you have got sufficient water pressure, and that the cold inlet is not frozen.
If everything seems o/k, then you could have a faulty inlet valve.
Hope this helps.
Jan 09, 2010 | Hotpoint Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
H20
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Thanks.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Does anybody know what H20 code stands for?
H20 code stands for low water pressure. In case it flashes on the screen, disconnect the hot and cold pipe and check them to see if there is enough water pressure
Dec 12, 2008 | Hotpoint Ultima WD72 Front Load...
Prewash flash
If the pre wash led is flashing it indicates a h20 error (time out filling) some common causes are fill hose twisted trapped or kinked tap not turnd on the waste hose is connected incorectly and is causing the applionce to syphone if your waste pipe gose into a down pipe ensure it is in no more than 4 inches maximum and if it is connected to the u bend undr the sink you need to make sure the pipe gose above 60cm high at some point.
Feb 20, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
561 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
