Question about Microwave Ovens
There is no electricity getting to it. Just dead. Is there a fuse or something I could look for? Help
    President:
  • 2,080 Answers
You can download the online parts List and service diagrams for your model at the following link:
http://www.appliancepartspros.com/
To view the service diagrams just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated. Then just enter the model number of your microwave oven.
You may need ADOBE READER installed on your computer to read PDF documents like the diagrams.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I will assume you have checked the house's main circuit panel for any tripped breakers and tested the electrical wall outlet for a good power supply. Reset the house circuit breaker at the panel if necessary.
Otherwise, hopefully the problem is just a blown main fuse inside the microwave. In order to access and check this you will have to disconnect the power cord and then remove the oven from the wall if it is an overhead model. Then remove the case in order to access the electrical parts inside.
Components inside the microwave like the main capacitor can remain EXTREMELY dangerous even after the power cord is disconnected. So if you are not familiar with basic electrical safety precautions when working with this type of equipment, then you should leave this kind of task for a trained appliance technician.
Here is a picture of a generic main fuse for a microwave:
http://www.appliancepartspros.com/part_details.aspx?part_id=4440371
Just replace the fuse with an exact match and reassemble. If you tested the old fuse and it was still good, then you may be dealing with a more complicated and expensive fix possibly involving the control panel circuit board. At that point you may want to consider seeking additional assistance or just getting a new oven.
Thank you very much and good luck.
Joe
Posted on May 19, 2011
My Intellichef microwave model #K0936 has stopped working. I've tried different outlets but the microwave is not responding. Is there an internal fuse that has blown or is the microwave dead?
If the fuse is blown the microwave will be "dead". The fuse is accessed by removing the cover. You can usually find the fuse by following the power cord into the microwave. Unplug the microwave and don't touch anything except the fuse as the capacitor can hold an electrical charge.
Nov 02, 2017 | Microwave Ovens
Should i keep the capacitor installed in the microwave before testing? Should i plug the microwave to electricity. Before testing?
please do not proceed. blown fuses is usually because of a bad door switch. there are three or more on every m/w. triple redundancy so high voltage radiation wont leak out and cook you instead of your food. or some times a shorted high voltage capacitor. ! it stores 2000 volts and can kill no joke. so discharge it with a plastic handle screwdrivers :) electricity "its SHOKING "
Jan 06, 2015 | In Microwave Ovens
My microwave went dead while heating up something what could it be
It probably blew the main fuse. Since it blew when it was running, it might indicate that the fuse holder isn't holding the fuse tightly enough; causing it to heat and internally melt.
You also could have some sort of failure, or failing component, in the high voltage circuit.
Jun 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse problem
I very much doubt it, chances are it has blown a capacitor or something along those lines, however the fuse in the mains plug should have blown before any damage was done, that's what they are there for, so if the fuse in plug is ok I think your microwave has had it.
Nov 08, 2013 | General Electric PVM1870SMSS Microwave...
No power. it is completely dead. wondering if it got struck by lightning.
Nine out of ten microwave ovens are protected to a degree by a fuse. This fuse is usually located near or right at the rear of the unit, accessible by removing the outer shell. This is not something one with no knowledge of electricity and electronics should attempt to do, however, it's a fairly simple repair for a shop. The problem is finding one you feel you can trust not to rip you off for an expensive repair when all they had to do was check the continuity of the fuse and replace it.
Jul 14, 2011 | GE Microwave Ovens
No electricity Clock is off nothing works
Plug something else into the outlet and see if the device works if it doesn't then reset the breakers. If the other device does work then the microwave is bad and needs replacement.
May 29, 2010 | Whirlpool MH7140XF Microwave Oven
Will not heat
Begin by plugging something else into that outlet. If the outlet is dead you will have to check the electrical panel and either reset the breaker or replace the fuse.
If you have power at that outlet and the microwave just won't heat you are going to be better off getting a new one than paying for a repair.
Oct 02, 2009 | Microwave Ovens
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Maytag MMV4205AA - Just went dead
It is a thermal fuse Ijust don't know where it is located
Apr 15, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
