Question about Haier Dehumidifiers
Does not start, no lights on, Outlet checked. Not tank-full
    Sergeant:
    Champion:
  • 229 Answers
Just replace the dehumidifier its not cost effective to put any money or time into it.
Posted on May 19, 2011
Dehumidifier will not start
You emptied the tank, right?
Sep 02, 2014 | Maytag Dehumidifiers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Why did my dehumidifier suddenly stop dehumidifying, fan works fine
check that the tank isn't full or the outlet hose is not blocked. Remove the filters and clean if required.
Jul 27, 2014 | Fedders A7DH45B2A Dehumidifier
My Kenmore Dehumidifier wont turn on. There is power to it ,all the indicator lights are on, it just wont start. What's wrong?
Check the over fill switch in the tank. If this is stuck it thinks the tank is full and won't come on. After that your compressor may be bad or the starter for the compressor. The Dehumidifier is basically a small air conditioner that condenses moisture in the air then it drains into the tank.
Jul 13, 2011 | Kenmore Dehumidifiers
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
Full light comes on early
Most dehumidifiers rely on a float sitting in the pail to rise, turning off the switch. Check and see if the float moves clean and smooth, and is sitting in the pail rather than resting on it's brim.
There may be other safety switches, like a temperature sensor to turn it off if it runs the risk of freezing up or overheating.
Sep 18, 2008 | Maytag M7DH45B2A Dehumidifier
Figidaire 25 pint dehumidifier
Check the point on the tank (Bucket) where the hose connects to. Make sure there is no obstruction at the outlet of the bucket to the hose connection. Next make sure the hose has no kinks or no loops that may trap air to the drain. If necessary for a long run to the place of drainage raise the dehumidifier to a higher level for better drainage.
Jun 20, 2008 | Frigidaire FDL45P1 Dehumidifier
Water tank still gets full when connected to floor drain
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Jun 07, 2008 | Danby DDR600R Silhouette Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Dehumidifiers Logo
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
